7303 Discussions
MKL Matrix multiplication: undefined reference to `mkl_blas_dgemv'
bsukhwani
I am trying to link to the MKL library (over a network). I can get MKL FFT to work but while calling a BLAS routine (Matrix Multiplication),
I get the following compile time error:
/mkl/lib/em64t/libmkl_core.a(_def_xdgemm.o): In function `mkl_blas_def_xdgemm':
__tmp_xdgemm.c:(.text+0xb27): undefined reference to `mkl_blas_dgemv'
I am using the example code that came with the MKL. The function call that leads to this error is 'cblas_dgemm'
I am compiling using the following command:
icc -o MatrixMul_MKL cblas_dgemmx.c -L$MKLPATH -I$MKLINCLUDE -W1, --start-group $MKLROOT/lib/em64t/libmkl_intel_lp64.a $MKLROOT/lib/em64t/libmkl_sequential.a $MKLROOT/lib/em64t/libmkl_core.a -W1, --end-group -lpthread
Any help would be greatly appreciated.
-Bharat
TimP
Quoting - bsukhwani
You have mis-spelled the -Wl directives.
bsukhwani
Quoting - tim18
Hi Tim,
Thanks for the reply but that did not fix it. Still the same error.
-Bharat
Gennady_F_Intel
Quoting - bsukhwani
Quoting - tim18
Hi Tim,
-Bharat
then please check your if $MKLROOT provides the proper path to the MKL,
or
please try to build this example by using makefile
see $MKLROOT/examples/cblas/
examples of using:
make lib64 function=cblas_dgemmx+
--Gennady
bsukhwani
or
examples of using:
--Gennady
Great! Thanks!!
The $MKLROOT was already providing the proper path to the MKL. Using the makefile did the trick. Now it compiles fine.
This is what I used to make:
make libem64t function=cblas_dgemm
Thanks again,
Bharat
