MKL PARDISO error symbolic factorization -1
Xuye
HI!
I used MKL's pardiso to get the decomposition of one of my matrices. I tried many methods,but it always resulted in error symbolic factorization -1. I am new to C++ and MKL,so fogive me for not being able to articulate the issue clearly.I suspect it's an issue with the environment configuration, as the same code can be used to calculate cases on my teacher's computer. However, I have already linked the library and configured it properly.
Please give me some suggestions,thank you for your help!
Here are some of the codes
void CPoissonSolver::solve_lineareqn_mkl_symm()
int   jid, kid, nid, nn0, icount;
nn0  =  matVals_.size();
int  matrix_size = ndof_;
int *ia = new int[ matrix_size+1];   //next row start index
int *ja = new int[nn0];
double *a = new double[nn0];
double *b = new double[matrix_size];
double *x = new double[matrix_size];   /* RHS and solution vectors. */
icount = 0;
ia[0] = 1;
for(map<int,set<int>>::iterator it = matIds_.begin(); it != matIds_.end(); ++it )
jid = it->first;
for(set<int>::iterator sit = it->second.begin(); sit != it->second.end(); ++sit)
kid = *sit;
nid = jid * ndof_ + kid;
a[icount] = matVals_[nid];
ja[icount] = kid+1;
icount++;
ia[jid+1] = icount+1; //jav.size()+1;
// cout<<jid<<" ::  "<<icount<<" "<<ia[jid+1]<<endl;
cout<<"symmetric matrix!!!:";
cout<<" non zeros : "<<nn0<<"  "<<icount<<endl;
   for (int i=0;i < matrix_size;++i)
   b[i] = rhs_[i];
  /* cout<<matrix_size<<" :: ";
   for (int i=0;i <= matrix_size;++i)
   cout<<ia[i]<<" ";
   cout<<endl;
   for (int i=0; i < nn0;++i)
   cout<<a[i]<<" "<<ja[i]<<endl;
int nrhs = 1;                       /* Number of right hand sides. */
int mtype = -2;                     /* Real symmetric matrix */
    void *pt[64];                           /* Internal solver memory pointer pt, */
int iparm[64];                          /* Pardiso control parameters. */
int maxfct, mnum, phase, error, msglvl;
int i;
double ddum; /* Double dummy *//* Auxiliary variables. */
int idum; /* Integer dummy. */
for (i = 0; i < 64; i++)
iparm[i] = 0;
iparm[0] = 1;                              /* No solver default */
iparm[1] = 2; /* Fill-in reordering from METIS */
                  /* Numbers of processors, value of OMP_NUM_THREADS */
iparm[2] = 1;//omp_get_max_threads();
iparm[3] = 0; /* No iterative-direct algorithm */
iparm[4] = 0; /* No user fill-in reducing permutation */
iparm[5] = 0; /* Write solution into x */
iparm[6] = 16; /* Default logical fortran unit number for output */
iparm[7] = 2; /* Max numbers of iterative refinement steps */
iparm[8] = 0; /* Not in use */
iparm[9] = 13; /* Perturb the pivot elements with 1E-13 */
iparm[10] = 1; /* Use nonsymmetric permutation and scaling MPS */
iparm[11] = 0; /* Not in use */
iparm[12] = 0; /* Not in use */
iparm[13] = 0; /* Output: Number of perturbed pivots */
iparm[14] = 0; /* Not in use */
iparm[15] = 0; /* Not in use */
iparm[16] = 0; /* Not in use */
iparm[17] = -1; /* Output: Number of nonzeros in the factor LU */
iparm[18] = -1; /* Output: Mflops for LU factorization */
iparm[19] = 0; /* Output: Numbers of CG Iterations */
maxfct = 1; /* Maximum number of numerical factorizations. */
mnum = 1; /* Which factorization to use. */
msglvl = 0; /* Don't print statistical information in file */
error = 0; /* Initialize error flag */
/* .. Initialize the internal solver memory pointer. This is only */
/* necessary for the FIRST call of the PARDISO solver. */
pt[i] = 0;
/* .. Reordering and Symbolic Factorization. This step also allocates */
/* all memory that is necessary for the factorization. */
phase = 11;                           //only reordering and symbolic factorization
PARDISO (pt, &maxfct, &mnum, &mtype, &phase,
&matrix_size, a, ia, ja, &idum, &nrhs,
iparm, &msglvl, &ddum, &ddum, &error);
if (error != 0)
printf("\nERROR during symbolic factorization: %d", error);
exit(1);
printf("\nReordering completed ... ");
printf("\nNumber of nonzeros in factors = %d", iparm[17]);
printf("\nNumber of factorization MFLOPS = %d", iparm[18]);
Labels (2)
Gennady_F_Intel
error code -1 means input inconsistency ( it means that your input matrix is not align with CSR matrix format representations.
you might be enable matrix checker via setting iparm[26] == 1. In this case Pardiso will check arrays ia and ja, in particular, MKL Pardiso will check whether column indices are sorted in increasing order withing each row.
