MKL PARDISO pivot function fault
YC_H_
HI all,
I tried to implement mkl_pardiso_pivot() in my program.
Sometime, it will cause a segmentation fault in a function in mkl_intel_thread.so.
Does anyone experience the same situation?
Gennady_F_Intel
This is an unknown problem for the current ( 11.2.1 ) version of MKL.  What version are you using? Can you give the example?
YC_H_
I encountered this problem since 11.2.0.
Sometime it works fine.
I used debugger to trace down this problem and found that It crashed in opm_xxx functions in mkl_intel_thread.so.
At first, I thought it's my problem to misuse the threading but I didn't do anything about it.
Hope that there is an explanation and resolution about it.
Thanks!
