MKL Parallelism problem
sspine
I'm trying MKL10 with OpenMP on dual-core linux machine.
The MKL user's guide told me:
In Intel MKL 10.0, the OpenMP* software determines the default
number of threads. The default number of threads is equal to the number
of logical processors in your system for Intel OpenMP* libraries.
But this is not the truth for me. I have tried cblas_dgemm function (matrix multiply) using the default settings, MKL only uses one core for the calculation. But after I set the environment variable MKL_NUM_THREADS to 2, the MKL can utilize both cores, and the calculation time is about 1/2 of the first case.
The following are my settings:
MKL: 10.0.4.023 with customized shared library
OS: SuSE Linux 10.2, 32-bit
CPU: Intel Core2 Duo
Can someone tell me what on earth the default behaviour of MKL as for MKL_NUM_THREADS?
Thanks!
sspine
No one can answer this question?
MKL user manual tells me that the default value of OMP_NUM_THREADS=2. But the user manul does not tell me the default value of MKL_NUM_THREADS. I guess MKL_NUM_THREADS=1 by default. Since MKL_NUM_THREADS takes precesence over OMP_NUM_THREADS, the multi-core support is disabled by default. If this is the truth, it can be approved by my experiment.
Another question is function set_mkl_num_threads() will depend on what libraries? Linux always tell me that some functions unavailable, but I do not know where can I find them.
Vladimir_Lunev
Quoting - sspine
MKL uses "Number of physical cores" threads by the default. If you has set MKL_NUM_THREADS or OMP_NUM_THREADS to the positive value then this value is used instead of the default.
Please, how did you link MKL?
-Vladimir
