MKL_SINGLE_PATH_ENABLE
Arnaud
We have legacy code that call :
mkl_enable_instructions(MKL_SINGLE_PATH_ENABLE);
MKL_SINGLE_PATH_ENABLE is not in the documentation (anymore ?).
In mkl_service.h, defines are :
#define  MKL_ENABLE_SSE4_2          0
#define  MKL_ENABLE_AVX             1
#define  MKL_ENABLE_AVX2            2
#define  MKL_ENABLE_AVX512_MIC      3
#define  MKL_ENABLE_AVX512          4
#define  MKL_ENABLE_AVX512_MIC_E1   5
#define  MKL_SINGLE_PATH_ENABLE     0x0600
Does anyone know if MKL_SINGLE_PATH_ENABLE is still used in MKL 2017 (still present in mkl_service.h) ? Can we consider that it is the most restrictive mode ?
Thank you.
Arnaud
Jing_Xu
I’m not sure that MKL_SINGLE_PATH_ENABLE was ever documented.
It's still working, though, please use mkl_cbwr_set(MKL_CBWR_COMPATIBLE)- that has exactly same behavior to MKL_SINGLE_PATH_ENABLE.
Jing_Xu
