MKL_VERBOSE
Kevin_H_3
  It would be useful to limit the output of MKL_VERBOSE on a per-thread basis. For example, assuming the use of a KNL and you are running 1 process with 16 threads. You may want to limit the MKL_VERBOSE output from only 1 calling thread. (though KML calls may be using multiple threads)
Gennady_F_Intel
Interesting, thanks for the feedback Kevin. That's not possible right now. We will check what we may do with this request and keep you updated.
Kevin_H_3
  Thank you. I believe with the increased scale out of threads and cores on CPUs, being able to limit the output is likely useful for many.
kevin
