MKL bug in function dgesvd?
jeff33
A call of dgesvd with a random matrix results in a segmentation fault. I work with MKL 8.0.2 on a Pention IV with Linux. A call of dgesvd with the same matrix using LAPACK leads to no error.
My program reads:
program ftest
integer M
integer N
integer Q
integer LWORK
parameter (M=300)
parameter (N=400)
parameter (Q=300)
parameter (LWORK=100000)
double precision A(M,N)
double precision U(M,M)
double precision VT(N,N)
double precision S(Q)
double precision WORK(LWORK)
integer INFO
do i=1,M
do j=1,N
A(i,j) = rand(0)
end do
end do
call dgesvd('A','A',M,N,A,M,S,U,M,VT,N,WORK,LWORK,INFO)
stop
end
I compile it with the command:
ifort ftest.f -lmkl_lapack -lmkl -lguide -o ftest
Is this a MKL-bug or a wrong usage of the function dgesvd?
Thanks for your interest!
hajek
Works fine with MKL 7.2 (Cluster)
max57
Segmentation fault also with MKL 8.0 on an Intel Xeon 64bit. According to the debugger, the error is in function mkl_blas_dgemm_copybt() in libmkl_p4n.so.
sragner
http://softwareforums.intel.com/en-us/forums//topic/51912
I have a similar problem 8.0.1 with matrix sized 350x320. Couldn't find any solution.
Laszlo
