7303 Discussions
MKL compile problem in 64bit Linux using 64bit compiler.
Henrik_S_
I am running OpenSuse 10.3, 64bit. When I compile a sample VSL function using the fc (32bit) compiler:
make lib32 function=vdrngbeta.f
it works fine. so32 works as well. The VSL sample program vdrngbeta.f is arbitrary... all VSL programs work.
When I try to compile the same program using the fce (64bit) compiler:
make lib64 function=vdrngbeta.f
I get 50+ error messages of this type:
ld: ia64-elf64 architecture of input file `.../mkl/lib/64/libmkl_intel_lp64.a(vsl_dbeta.o)' is incompatible with i386:x86-64 output
how do I fix this? When I:
make so64 function=vdrngbeta.f
.../mkl/lib/64/libmkl_intel_lp64.so: could not read symbols: File in wrong format
make[1]: *** [vdrngbeta.res] Error 1
Similar problem it seems. What am I doing wrong?
- henrik
Henrik_S_
I think I answered my own question.
make libem64t function=vdrngbeta
I guess lib64 is for the IA64 architecture?
Sincerely,
- Henrik
Gennady_F_Intel
Yes, you are right:
Lib64 build examples of MKL for Intel Itanium processor family
--Gennady
