7299 Discussions
MKL fatal error when trying to compile fortran code
Nasim_hossain
Hello, I am trying to run a CFD simulation code that is written using fortran. I use ifort for compiling all of my fortran codes(Installed one api baseline toolkit and hpc toolkit latest version 2022.2). Previously I ran the same code without any issue. But recently whenever I am trying to run the code I am getting an MKL error. I have included the whole error below:
Intel MKL FATAL ERROR: This system does not meet the minimum requirements for use of the Intel(R) Math Kernel Library.
The processor must support the Intel(R) Supplemental Streaming SIMD Extensions 3 (Intel(R) SSSE3) instructions.
The processor must support the Intel(R) Streaming SIMD Extensions 4.2 (Intel(R) SSE4.2) instructions.
The processor must support the Intel(R) Advanced Vector Extensions (Intel(R) AVX) instructions.
Previously I ran the code without any issue but now I am wondering what could be the potential cause behind this.
Thank you in advance.
Steve_Lionel
This is not a Fortran or compile issue. I suggest asking in Intel® oneAPI Math Kernel Library - Intel Communities
Barbara_P_Intel
I'll move this to the MKL Forum.
Nasim_hossain
Dear Barbara, I am unable to delete this post. I already submitted same question to the MKL forum. It would be better if you remove this. Thank you very much.
