MKL function dgetrf wrong results
dimdol10
Hello!
I am using Intel oneAPI MKL version 2022.2, and visual studio 2022.
I am currently trying a LU decomposition of a matrix using the function DGETRF provided by MKL.
As I found a wrong result in a simple example, I would like ask you if something is incorrect. The example code is attached in the below. As far as I understood, in this example, the array ipiv should be
ipiv(1) = 2,
ipiv(2) = 1,
such that
A_PLU = P*L*U.
However, the function gives
ipiv(1) = 2,
ipiv(2) = 2.
PROGRAM TEST_MAT_LU_FAC_INV
DOUBLE PRECISION A(2,2)
DOUBLE PRECISION A_L(2,2), A_U(2,2)
DOUBLE PRECISION A_LU(2,2)
DOUBLE PRECISION A_PLU(2,2), A_PLU_TEST(2,2)
integer info
integer ipiv(2)
DOUBLE PRECISION P(2,2) ! permutation matrix
A = 0.D0
A(1,1) = 1.D0
A(1,2) = 2.D0
A(2,1) = 3.D0
A(2,2) = 4.D0
CALL DGETRF(2,2,A,2,ipiv,info)
A_L = 0.d0
A_L(1,1) = 1.D0 !A(1,1)
A_L(2,1) = A(2,1)
A_L(2,2) = 1.D0 !A(2,2)
A_U = 0.D0
A_U(1,1) = A(1,1)
A_U(1,2) = A(1,2)
A_U(2,2) = A(2,2)
A_LU = 0.D0
DO I = 1,2
DO J = 1,2
DO K = 1,2
A_LU(I,J) = A_LU(I,J) + A_L(I,K)*A_U(K,J)
END DO
END DO
END DO
P = 0.D0
DO I = 1,2
P(I,IPIV(I)) = 1.D0
END DO
A_PLU_TEST = 0.D0
DO I = 1,2
DO J = 1,2
DO K = 1,2
A_PLU_TEST(I,J) = A_PLU_TEST(I,J) + A_L(I,K)*A_U(K,J)
END DO
END DO
END DO
A_PLU = 0.D0
DO I = 1,2
DO J = 1,2
DO K = 1,2
A_PLU(I,J) = A_PLU(I,J) + P(I,K)*A_PLU_TEST(K,J)
END DO
END DO
END DO
END
ShanmukhS_Intel
Hi Myung,
Thanks for posting on Intel Communities.
Could you please cross-verify the shared source code? We tried compiling it and we couldn't see any output.
Shanmukh.SS
dimdol10
Dear Shanmukh,
Thanks for the reply.
Yes, the code print out nothing. But, what I meant is that the array A_PLU is supposed to be the same with the array A. However, if you run the code, you can find that they are different.
A_PLU(1,1) = 1.D0
A_PLU(2,1) = 1.D0
A_PLU(1,2) = 2.D0
A_PLU(2,2) = 2.D0
I suspect the output array ipiv from DGETRF is wrong. Could you please take a look at this point?
Thank you very much.
ShanmukhS_Intel
Hi Myung,
Please find the below link for more details and usage regarding the DGETRF functionality.
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-fortran/top/lapack-routines/lapack-linear-equation-routines/lapack-linear-equation-computational-routines/matrix-factorization-lapack-computational-routines/getrf.html
The function describes the input parameters to be used and the proper usage of the routine.
Shanmukh.SS
ShanmukhS_Intel
A gentle reminder:
We have not heard back from you for a while. Could you please let us know if any updates regarding your issue?
Shanmukh.SS
ShanmukhS_Intel
Hi Myung,
We assume that your issue is resolved. If you need any other information, please post a new question as this thread will no longer be monitored by Intel.
Shanmukh.SS
