MKL in OneAPI 2024.1
EMagee
I have run into an issue with the MKL library from OneAPI 2024.1.0 on a couple Linux platforms. I am getting incorrect results from one of the function (vdTGamma, specifically). If I compare the results from this function between using OneAPI 2023.2.0 and 2024.1.0 I get different results. I have verified the results are correct from 2023.2.0. I have attached an CPP file (with a CMake.txt) to demonstrate. To build the example:
> export MKLROOT=<location of onapi 2023.2>/mkl/latest
> export COMPILERLIBDIR=<location of onapi 2023.2>/compiler/latest
> mkdir build
> cd build
> cmake ..
> make
> ./vdTGamma
vdTGamma test/example program
Argument  vdTGamma   expected
-1.3499   +2.9314    +2.9314
+3.0349   +2.0660    +2.0660
+0.7254   +1.2596    +1.2596
-0.0631   16.4914    16.4914
+0.7147   +1.2754    +1.2754
-0.2050   5.7068     5.7068
-0.1241   8.7741     8.7741
+1.4897   +0.8859    +0.8859
+1.4090   +0.8868    +0.8868
+1.4172   +0.8865    +0.8865
Error! Maximum error is -0.0000
Now using 2024:
> export MKLROOT=<location of onapi 2024.1>/mkl/latest
> export COMPILERLIBDIR=<location of onapi 2024.1>/compiler/latest
> rm -rf *
> cmake ..
> make
> ./vdTGamma
-1.3499   +2.6115    +2.9314
-0.0631   inf        16.4914
-0.2050   inf        5.7068
-0.1241   inf        8.7741
Error! Maximum error is   -inf
Has anyone else seen this?  My caode, and CMake file are attrached.
Gennady_F_Intel
What kind of CPU you are running your code here?
I see no problem here while building against oneMKL 2024.1 ( the current one) and 2023.2 and running on Intel(R) Xeon(R) Gold 6148 CPU @ 2.40GHz.
I slightly updated your example by adding mkl_get_version(*.*) routine to print info about version of MKL used:
Compiling: icpx -std=c++11 -qmkl vdTGammaTest.cp
Results obtained:
MKL 2023 u2:
-0.0631 -16.4914 -16.4914
-0.2050 -5.7068 -5.7068
-0.1241 -8.7741 -8.7741
MKL version: 2023.0.2, CPU: Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) enabled processors
MKL 2024 u1:
MKL version: 2024.0.1, CPU: Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) enabled processors
--Gennady
EMagee
Here are the outputs from two different systems.  Let me know if you need additional information.  System 1 is an HPE Cray EX with the AMD 7H12 Rome processor  and the SLES OS.  System 2 is a Penguin Computing TrueHPC system with the AMD 7713 Milan  and the RHEL OS.  NOTE: I had to add pthread, m, and dl to the link line for system 2.
System 1 with 2023, output from CMake:
-- The C compiler identification is GNU 10.3.0
-- The CXX compiler identification is GNU 10.3.0
-- Check for working C compiler: /opt/cray/pe/craype/2.7.19/bin/cc
-- Check for working C compiler: /opt/cray/pe/craype/2.7.19/bin/cc - works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /opt/cray/pe/craype/2.7.19/bin/CC
-- Check for working CXX compiler: /opt/cray/pe/craype/2.7.19/bin/CC - works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
vdTGamma: Using MKL in /opt/intel/oneapi_2023.2.0.49397/mkl/latest with ...
   MKL_LIB_DIR: /opt/intel/oneapi_2023.2.0.49397/mkl/latest/lib/intel64 ...
   COMPILER_LIB_DIR: /opt/intel/oneapi_2023.2.0.49397/compiler/latest/linux/compiler/lib/intel64_lin ...
Major version:          2023.0.2
Build:                  20230613
Platform:               Intel(R) 64 architecture
Processor optimization: Intel(R) Architecture processors
System 1 with 2024, output from CMake:
vdTGamma: Using MKL in /opt/intel/oneapi_2024.1.0.596/mkl/latest with ...
   MKL_LIB_DIR: /opt/intel/oneapi_2024.1.0.596/mkl/latest/lib/intel64 ...
   COMPILER_LIB_DIR: /opt/intel/oneapi_2024.1.0.596/compiler/latest/lib ...
Major version:          2024.0.1
Build:                  20240215
-0.0631     -inf     -16.4914
-0.2050     -inf     -5.7068
-0.1241     -inf     -8.7741
System 2 with 2023, CMake output:
-- The C compiler identification is GNU 8.5.0
-- The CXX compiler identification is GNU 8.5.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc - works
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ - works
vdTGamma: Using MKL in /p/app/compilers/intel/oneapi-2023.1.0/mkl/latest with ...
   MKL_LIB_DIR: /p/app/compilers/intel/oneapi-2023.1.0/mkl/latest/lib/intel64 ...
   COMPILER_LIB_DIR: /p/app/compilers/intel/oneapi-2023.1.0/compiler/latest/linux/compiler/lib/intel64_lin ...
Major version:          2023.0.1
Build:                  20230303
System 2 with 2024, CMake output:
vdTGamma: Using MKL in /p/app/compilers/intel/oneapi-2024.1.0/mkl/latest with ...
   MKL_LIB_DIR: /p/app/compilers/intel/oneapi-2024.1.0/mkl/latest/lib/intel64 ...
   COMPILER_LIB_DIR: /p/app/compilers/intel/oneapi-2024.1.0/compiler/latest/lib ...
Build:                  20240215
EMagee
Side note: just out of curiosity, I tried vsTGamma with 2024 and it worked fine.
EMagee
Another side note.  I was able to test this on an additional machine using 2024 and it works fine.  System 3 is an HPE Cray EX4000 with the AMD 9654 Genoa processor  and the SLES 15 OS.  Here is the output:
Major version:          2024.0.0
Build:                  20231011
Argument  vdTGamma   std::tgamma
Error! Maximum error is 0.0000
u
Gennady_F_Intel
yes, I have to reproduced the behavior while running this case on Genoa CPU. We will root-caused the problem and keep this threads updated.
--Gennady
Gennady_F_Intel
Erik,
yesterday the last version of oneMKL ( 2024.2) has been released and available for download. The problem You reported has been fixed.
You could take 2024.2 and evaluate this fix.
here is what I see running this example on Genoa CPU.
MKL version: 2024.0.2, CPU: Intel(R) Architecture processors
I also attached the all needed details about CPU, OS, linking and obtained results - see _2024u2_Genoa.txt .
