MKL, macOS, and GNU Fortran
Matt_Thompson
Intel MKL Gurus,
A quick question: why is GNU Fortran not an accepted compiler for MKL on macOS?
(1264) $ $MKLROOT/tools/mkl_link_tool --os=mac -libs --compiler=gnu_f --parallel=no
       Intel(R) Math Kernel Library (Intel(R) MKL) Link Tool v4.4
Not supported compiler for current configuration:gnu_f. Supported values for compiler: intel_c|intel_f|gnu_c|clang|pgi_f|pgi_c
Configuration
OS:                     mac
Architecture:           intel64
Compiler:               gnu_f
Linking:                dynamic
Interface layer:        lp64
Parallel:               no
OpenMP library:         iomp5
I'm sure there is a good reason, but as I use GNU Fortran a lot on my Macbook (hey, free compiler) and MKL is free(-ish) at least for my experimenting/fiddling so it would be a nice option to use if I could.
Matt
Ying_H_Intel
Hi Matt,
Thank you for raising the question here. we will check and get back to you later.
 It seems because historical reason - in some early version, the MKL for Mac OS is packaged as subcomponent of  Intel parallel studio composer. So mainly support Intel fortran Compiler on Mac OS.
Ying
Zhen_Z_Intel
Hi Matt,
There's indeed some problem with mkl_link_tool, we will investigate. Please refer to use MKL link advisor help you generating link line. Thanks.
Fiona
Matt_Thompson
Fiona,
Sadly it looks like the online MKL Advisor doesn't have the option for gfortran+macOS either (probably because it's just running the command line tool underneath somewhere, I assume). I'm currently trying to figure out a good way to automate getting link lines in a make system. ifort is the easy one, it's PGI, GNU, etc. that take some auto-entry into the tool.
Ying_H_Intel
Hi Matt,
Right, both MKL link tool and advisor haven't such option.  We don't support gfortran on Mac OS for a while.  What i can recommend may be to use Intel fortran or PGI so far.  Do you like we to create a feature request to support gfortran?
Ying
Matt_Thompson
Ying,
I would definitely like a feature request for supporting gfortran on macOS. I don't imagine it would be that difficult (fingers crossed).
Matt
