7303 Discussions
MKL_malloc interface missing from Fortran module
Ben3
It looks like the interface for MKL_malloc is missing from the mkl_service Fortran 90 module, at least in the versions I have. Is it supposed to be in there? The documentation seems to indicate so, and the interface for mkl_free is definitely there.
Cheers,
Ben
Windows
14.0.2.176
Linux
$ grep -ic mkl_malloc composer*/mkl/include/mkl_service.f90
composer_xe_2011_sp1.10.319/mkl/include/mkl_service.f90:0
composer_xe_2011_sp1.13.367/mkl/include/mkl_service.f90:0
composer_xe_2011_sp1.6.233/mkl/include/mkl_service.f90:0
composer_xe_2011_sp1.8.273/mkl/include/mkl_service.f90:0
composer_xe_2011_sp1.9.293/mkl/include/mkl_service.f90:0
composer_xe_2013.0.079/mkl/include/mkl_service.f90:0
composer_xe_2013.1.117/mkl/include/mkl_service.f90:0
composer_xe_2013.2.146/mkl/include/mkl_service.f90:0
composer_xe_2013.4.183/mkl/include/mkl_service.f90:0
composer_xe_2013.5.192/mkl/include/mkl_service.f90:0
composer_xe_2013_sp1.0.080/mkl/include/mkl_service.f90:0
composer_xe_2013_sp1.1.106/mkl/include/mkl_service.f90:0
composer_xe_2013_sp1.2.144/mkl/include/mkl_service.f90:0
composer_xe_2013_sp1.3.174/mkl/include/mkl_service.f90:0
composerxe-2011.0.084/mkl/include/mkl_service.f90:0
composerxe-2011.3.174/mkl/include/mkl_service.f90:0
composerxe-2011.4.191/mkl/include/mkl_service.f90:0
composerxe-2011/mkl/include/mkl_service.f90:0
Gennady_F_Intel
declared in mkl_service.h.   there is an example -- <mklroot>\examples\servicefuncsf\source\ servicefuncs.f
Ben3
Yes, the C prototypes are in mkl_service.h, but that won't work for Fortran.
That example file has the MKL memory functions declared as external, rather than with using an explicit interface:
#ifdef _IA32
      INTEGER*4 MKL_MALLOC, MKL_CALLOC, MKL_REALLOC
      integer*4 ALLOC_SIZE, NUM_ELEM, SIZE_ELEM
#else
      INTEGER*8 MKL_MALLOC, MKL_CALLOC, MKL_REALLOC
      integer*8 ALLOC_SIZE, NUM_ELEM, SIZE_ELEM
#endif
      EXTERNAL   MKL_MALLOC, MKL_FREE, MKL_CALLOC, MKL_REALLOC
The documentation indicates that an interface should be available for both languages:
Intel® Math Kernel Library 11.1 Update 2 Reference Manual wrote:
Fortran Include Files/Modules
  • Include file: mkl.fi
  • Module (compiled): mkl_service.mod
  • Module (source): mkl_service.f90
C Include Files
  • mkl.h
However it's also missing from mkl.fi:
$ grep -ic malloc composer*/mkl/include/mkl.fi
composer_xe_2011_sp1.10.319/mkl/include/mkl.fi:0
composer_xe_2011_sp1.13.367/mkl/include/mkl.fi:0
composer_xe_2011_sp1.6.233/mkl/include/mkl.fi:0
composer_xe_2011_sp1.8.273/mkl/include/mkl.fi:0
composer_xe_2011_sp1.9.293/mkl/include/mkl.fi:0
composer_xe_2013.0.079/mkl/include/mkl.fi:0
composer_xe_2013.1.117/mkl/include/mkl.fi:0
composer_xe_2013.2.146/mkl/include/mkl.fi:0
composer_xe_2013.4.183/mkl/include/mkl.fi:0
composer_xe_2013.5.192/mkl/include/mkl.fi:0
composer_xe_2013_sp1.0.080/mkl/include/mkl.fi:0
composer_xe_2013_sp1.1.106/mkl/include/mkl.fi:0
composer_xe_2013_sp1.2.144/mkl/include/mkl.fi:0
composer_xe_2013_sp1.3.174/mkl/include/mkl.fi:0
composerxe-2011.0.084/mkl/include/mkl.fi:0
composerxe-2011.3.174/mkl/include/mkl.fi:0
composerxe-2011.4.191/mkl/include/mkl.fi:0
composerxe-2011/mkl/include/mkl.fi:0
I just wrote my own interface for it.
Cheers,
Ben
Gennady_F_Intel
Hello.
The issue has been fixed in MKL v.11.3.0 which has been released two days ago. Please check how it works and let us know if any further problems.
