7302 Discussions
MKL memory allocation: Is there an mkl_realloc?
bstrouse
I know that dynamic arrays being used by the Intel MKL functions needed to be allocated and deleted by the mkl_malloc and mkl_free. I was wondering if there was an mkl_realloc function provided in case you wanted to attempt and change the amount of memory allocated for a specific address stored inside a pointer.
Chao_Y_Intel
MKL only has the malloc functions, and no remalloc functions. mkl_malloc is calling the system malloc function, and it may allocate a little larger memory size, and make sure it can return the aligned the memory address. If you need to have a aligned remalloc function, I think may do something like that with system remalloc system call.
Chao
bstrouse
So basically, I would have to write my own remalloc function to replace the standard one. If I wanted to do this, do I only need to make sure that remalloc is assigning chunks in multiples of the byte alignment (for example 16 bytes alignment)?
Blake
Chao_Y_Intel
Blake,
I just have quick search, in windows, the system runtime library provide the API: _aligned_realloc:
http://msdn.microsoft.com/en-us/library/y69db7sx(v=VS.71).aspx
Chao
TimP
Then you should use the corresponding Microsoft aligned_malloc and free functions, in case the MKL definitions aren't fully compatible.
