MKL on VM of Centos 8
TABrea
I am trying to install a version of the MKL libraries on a VM of Centos 8 running on a Windows 10 Machine.  I keep running into issues with the Install.sh giving the error IA-32 architecture host is no longer supported.
Is there a way to manually install the libraries with out using the install.sh?  I just need the library that has the complex data types and FFTs.
Gennady_F_Intel
It is not available to do, but as a brute force workaround, if you already have this version of mkl installed, you just can copy all of *.so, *.a, and header files to this VM system and it should work.
Gennady_F_Intel
TABrea
Gennady_F_Intel
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
