7303 Discussions
MKL performance w/regard to transform length
mike_p_1
on https://software.intel.com/en-us/intel-mkl/details
The description of MKL perforce states:
"Fast Fourier Transforms
Intel MKL FFTs include many optimizations and should provide significant performance gains over other libraries ****** for medium and large transform sizes. ******" (emphasis mine).
What is the expected value of "medium"? I am comparing performance of MKL FFT against FFTPACK 5.1 and am seeing a break-even value that *I* think is quite large; way bigger than I expected.
My benchmark includes setup overhead for both MKL and FFTPACK and does a forward/backward transform. The retrieved data series is virtually the same as input.
Devorah_H_Intel
Hello Mike,
Can you please send us your test results in private message. I will investigate your question and get back to you with update.
Thank you,
Devorah
Dmitry_B_Intel
Hi Mike,
Performance of MKL FFT is measured without setup overhead.
Medium sizes of a 1D FFT are approximately 100...100k. A size becomes 'large' when the working data set does not fit in last level cache, which may vary depending on precision and placement of transform, parallelization, and the computer used.
Dima
