MKL ?trexc function
Fedor_M_
Good day to all.
I am a student. I'm doing matrix calculations.
There was a problem with using the ?trexc function of MKL that makes the reordering of Schur factorization
In particular, with it's two last parameters: lapack_int* ifst, lapack_int* ilst.
I can't understand, how to makes this reordering step by step.
For example: I have the eigenvalues of matrix after Schur reordering: {198, 59, -47, -147}.
Then, after function ?trexc with parameters ifst = {4, 3, 2, 1}, ilst = {1, 2, 3, 4}  I have the following reordering of EV:
{-147, 198, 59, -47}.
At first I thought, that i-st element of ifst become i-st element of ilst . By this logic it must be follows:
{198, 59, -47, -147}  --->  {-147, -47, 59, 198}. But after ?trexc I have: {198, 59, -47, -147}  --->  {-147, 198, 59, -47}.
In documentation written: "The element (or block) with row index ifst is moved to row ilst by a sequence of exchanges between adjacent elements (or blocks)".  But I have tried to do it, and I have wrong results again.
Please, help me.
Fedor Malashin
Ying_H_Intel
Hi Fedor,
Good day, please see the answer from our developer:
First of all, parameters IFST and ILST of ?TREXC are integer scalars (not arrays).
So in this example ?TREXC is called with IFST = 4 and ILST = 1 since it reads only one element from each of the pointers and the rest 3 elements are ignored.
Documentation says that IFST is move to ILST by adjacent exchanges like that:
Initial state:
ev1 = 198
ev2 = 59
ev3 = -47
ev4 = -147
After exchange ev4  with ev3:
ev1 = 198
ev2 = 59
ev3 = -147
ev4 = -47
After exchange ev3  with ev2:
ev1 = 198
ev2 = -147
ev3 = 59
ev4 = -47
After final exchange ev2 with ev1:
ev1 = -147
ev2 = 198
ev3 = 59
ev4 = -47
that is why the output is like  {-147, 198, 59, -47}.
Ying
Fedor_M_
Hi, Ying.
Thank you for your answer.
I understood this.
