MKL with Spark
Jacques_J_
I'm trying to use MKL with Spark using netlib-java. I included the folder containing the dlls in the Path variable and specified the following option to the JVM : -Dcom.github.fommil.netlib.BLAS=mkl_rt.dll
However, it doesn't work and I still get the following warnings :
17/08/10 14:22:09 WARN BLAS: Failed to load implementation from: mkl_rt.dll
17/08/10 14:22:09 WARN BLAS: Using the fallback implementation.
Any help would be greatly appreciated
Ying_H_Intel
Hi Jacques,
Do you use spark under windows?   mkl_rt.dll is window library, where mkl_rt.so is Linux library.  As it is dynamic library, you may add some environment LD_LIBRARY_PATH  or run script  source /opt/intel/mkl/mklvars.sh intel64  before run your spark application
what kind of application do you like to run based on MKL?  I may recommend one of data analysis accelerate library DAAL , which is based on MKL, have java /c/python interface,  and also work on Spark and MLlib.
get free DAAL from  https://software.intel.com/en-us/intel-daal
DAAL training webpage:
https://software.intel.com/en-us/intel-daal-support/training
DAAL Scala Spark sample  download from
https://software.intel.com/en-us/product-code-samples
Ying
