MKLConfig.cmake needs updating
Zohar
There's a find_package(TBB) on line 903, which fails since it's obsolete:
- There's no TBBConfig.cmake anymore.
- Installing standalone TBB does nothing.
You may also want to get your vcpkg port in order:
https://github.com/microsoft/vcpkg/discussions/41789
Chao_Y_Intel
Thank you for confirming that TBB 2022 can work in that environment.
We have also fixed the CMakefile TBB issue in the latest oneMKL 2025 release. In the updated CMakefile:
 if(NOT TBB_FOUND)
    if(MKL_SYCL_THREADING STREQUAL "tbb_thread")
      set(SYCL_COMPILER OFF)
      mkl_message(WARNING "TBB not found for the specified MKL_SYCL_THREADING: ${MKL_SYCL_THREADING}. MKL::MKL_SYCL target will not be available.")
    endif()
A warning will be issued when using the Intel Compiler to build the code if TBB is NOT present.
This warning will indicate that some MKL functionalities (such as the SYCL interface) depend on TBB and cannot be used.
CMake Warning at /opt/intel/oneapi/mkl/2025.0/lib/cmake/mkl/MKLConfig.cmake:117 (message):
  TBB not found for the specified MKL_SYCL_THREADING: tbb_thread.
However, the code can still be built without any issues if this interface is not utilized.
btw, if you also want to format code, it can choose "..."(expand toolbar) >> "</>".
thanks,
Chao
Chao_Y_Intel
I can find the TBB configuration file:
>ls /opt/intel/oneapi/tbb/2021.13/lib/cmake/tbb/
TBBConfig.cmake TBBConfigVersion.cmake
To use the TBB cmake, have you set the TBB environment?
Here is test CMakeList.txt :
project(MyProject VERSION 1.0)
find_package(MKL CONFIG REQUIRED)
add_executable(my_executable main.cpp)
target_link_libraries(my_executable MKL::MKL)
Only setting oneMKL environment, an error reported on finding TBB package:
>source /opt/intel/oneapi/mkl/latest/env/vars.sh
>cmake -DMKL_THREADING=tbb_thread ..
 but it set MKL_FOUND to FALSE so package "MKL" is considered to be NOT
 FOUND. Reason given by package:
 TBB not found for the specified MKL_THREADING: tbb_thread
Both setting oneMKL and TBB enviroment, the TBB package is found:
>source /opt/intel/oneapi/tbb/latest/env/vars.sh
-- Found /opt/intel/oneapi/mkl/2025.0/lib/libmkl_scalapack_ilp64.so
-- Found /opt/intel/oneapi/mkl/2025.0/lib/libmkl_cdft_core.so
-- Found /opt/intel/oneapi/mkl/2025.0/lib/libmkl_intel_ilp64.so
-- Found /opt/intel/oneapi/mkl/2025.0/lib/libmkl_tbb_thread.so
thanks,
Chao
Zohar
As I said, the standalone tbb installation, weirdly, didn't install anything: there was no oneapi/tbb dir.
But let's say it did. If it's a dependency of MKL, then MKL should install it. But it's not. MKL already contains the tbb files, and if you comment out the find_package(TBB)  code from the MKL cmakefile, then it works fine.
Chao_Y_Intel
What is the version of the standalone oneTBB there?
I checked the latest 2022 TBB standalone package, downloaded from here
https://www.intel.com/content/www/us/en/developer/tools/oneapi/onetbb-download.html?operatingsystem=windows&distribution-windows=offline
The CMake files at Windows are available after installation: at C:\Program Files (x86)\Intel\oneAPI\tbb\2022.0\lib\cmake\tbb
Similarly for Linux system as well.
Regarding oneMKL in the oneMKL MKLConfig.cmake file:
if(MKL_THREADING STREQUAL "tbb_thread" OR MKL_SYCL_THREADING STREQUAL "tbb_thread")
 find_package(TBB CONFIG COMPONENTS tbb)
By default, MKL_THREADING is set to "intel_thread" in Cmake files. It is not expected to report any error, even without TBB installed.
Users need manually set MKL_THREADING to "tbb_thread" in their CMake files or linkage lines for MKLConfig.cmake to use TBB threading.
If MKL_THREADING is set to "tbb_thread", TBB need to be installed first.
Zohar
I tried everything again.
I'm adding to MKLConfig.cmake before line 903:
message( "MKL_THREADING=${MKL_THREADING}" )
message( "MKL_SYCL_THREADING=${MKL_SYCL_THREADING}" )
My CMakeLists.txt is:
CMAKE_MINIMUM_REQUIRED( VERSION 3.30 )
project( prj )
find_package( MKL CONFIG REQUIRED )
link_libraries( MKL::MKL )
I'm running it like this:
mkdir build3
cd build3
call "C:/Program Files (x86)/Intel/oneAPI/compiler/2024.2/env/vars.bat"
cmake ^
-DCMAKE_BUILD_TYPE=Release ^
-DCMAKE_C_COMPILER=icx ^
-DCMAKE_CXX_COMPILER=icx ^
-DCMAKE_TOOLCHAIN_FILE=d:/vcpkg/scripts/buildsystems/vcpkg.cmake ^ -DVCPKG_TARGET_TRIPLET=x64-windows ^
-G Ninja ^
-Wno-dev ^
cd ..
The output is:
MKL_THREADING=intel_thread
MKL_SYCL_THREADING=tbb_thread
CMake Error at D:/vcpkg/scripts/buildsystems/vcpkg.cmake:859 (_find_package):
Could not find a package configuration file provided by "TBB" with any of
the following names:
TBBConfig.cmake
tbb-config.cmake
If I install tbb 2022 (worked this time) from here
then it works fine since it finds tbb.
How to I format code when posting on the forum? Usually, it's done using backticks.
Chao_Y_Intel
 if(NOT TBB_FOUND)
    endif()
thanks,
Chao
Zohar
