_MSC_VER mismatch again
Xu_W_
Hi, Today I upgraded my MKL installation from 2017.0 to 2017.2 and recompile my application, then I got the following link error: 1>mkl_tbb_thread.lib(vml_tbb_threading_templates.obj) : error LNK2038: mismatch detected for '_MSC_VER': value '1600' doesn't match value '1900' in libboost_system-vc140-mt-1_62.lib(error_code.obj) And I found a similar bug did exist in a previous MKL version: https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/629012 Please fix it in the next MKL release. Thanks.
Ying_H_Intel
Hi Xu W,
thank you much for the report.
We will check it  and could you please let us know what version of Microsoft visual studio.
Ying
Just FYI: MSC_VER mismatch  in  https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/629012
To work-around it, you may add '-D_ALLOW_MSC_VER_MISMATCH -D_ALLOW_ITERATOR_DEBUG_LEVEL_MISMATCH' to the compile line to disable MSVS version checks.
Xu_W_
Hi ​Ying H.,
I'm using Visual Studio 2015 with Update 3, native x64 compiler.
Ying_H_Intel
The issue is supposed to be fixed in latest version. Please check :  https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/743816
Ying
