Matrix Determinant
JBervel
there is any way to calculate the determinant of a matrix in CSR3AC or COO format?
mecej4
Is finding the determinant the only objective, or is that just a side result in some other computation? If the latter, what does that computation consist of? What is the typical size of the matrix?
JBervel
No, the objective is to obtain the inverse matrix.
The size of the matrix can go from 4x4 to 2000x2000 elements, where about the 20% of the values is diferent from zero.
The matrix will always be square.
Alexander_K_Intel2
So you want to getdeterminant of sparse matrix or inverse of it? If you want to get inverse matrix you could obtain it by PARDISO functionality with many rhs.
With best regards,
Alexander Kalinkin
JBervel
I want to get the determinant of a sparse matrix, but I only have found the functions:
mkl_dcsrsm
mkl_dcoosm
where I can assign alpha = 1 and B = to theidentity matrix in order to get the inverse of the matrix A. But the documentation of these functions does not say anything about what happens when the determinant of A is zero. That is the reason I was looking for a function to get the determinant.
I did not know about PARDISO to obtain the inverse. Is this the best option for the type of matrices I am working with?
mecej4
You do not need to compute the determinant to establish whether the matrix is singular. The routines used for matrix factorization will return with a suitable error code when singularity (to a user specified tolerance) is detected.
Please state what you propose to do with the inverse. Quite often, if the solution of sparse systems of linear equations with multiple right hand sides is needed, that can be obtained without using the inverse. In fact, there are many reasons why the inverse should not be explicitly formed, except in a small number of special cases.
Alexander_K_Intel2
Please look this topic: (http://software.intel.com/en-us/forums/showthread.php?t=80373), there is a way to compute invert sparse matrix. Using dss_statistics routine (lookIntel Math Kernel Library ReferenceManualfor more details)you could obtain determinant of initial matrix.
With best regards,
Alexander Kalinkin
JBervel
I need the inverse for the next operation:
M = -inv(A)*B
where A is of size NxN and B is of size NxM. A and B are sparse matrices with less than 20% of elements diferent from zero.
A is a submatrix from a sparse matrix C of size NxK (K>N). WhenA is singular, I have to obtain another submatrix from C, and try again.
mecej4
Fair enough. The singularity of A, if true, will manifest itself during the factorization of A. Note that B is not involved in this question at all. The inverse of A should not be sought. Here is a sketch of the algorithm:
1. Choose a submatrix of C as A.
2. Attempt the sparse factorization of A.
3. If Step-2 fails,
3a. Go to Step-1, choosing a different submatrix.
else
3b. Solve A X = B using the factors of A formed in Step-2.
-- done --
JBervel
Thanks for your response mecej4,
I am testing with pardiso algorithm.
I execute the phases 11, 22, and 33. When the matrix A is singular,
the phase 33 returns the values IND in the array X.
But, how can I know in the phase 22 if the matrix A is singular?
Alexander_K_Intel2
The simplest way is to use dss interface instead of PARDISO. Then, as I mentioned before, dss_statistics routine could return determinant of initial matrix. To use PARDISO interface i need to know the value of mtype in you program, could you provide it?
With best regards,
Alexander Kalinkin
JBervel
Hi Alexander,
the value of mtype is 11.
Alexander_K_Intel2
it is not clear for me whay you got IND values in solution vector. Could you send small testcase and linkline to me to reproduce this problem on my side? By the way, in your term, as I understood you want to find matrix C with nonzero determinant as submatrix A. Could it happened that there is not such submatrix? (rang(A) < min (N,M))
With best regards,
Alexander Kalinkin
JBervel
this is a code where I obtain the values IND in the solution vector:
[cpp]#include
#include
using std::cout;
using std::endl;
int main()
	//Solver internal data address pointer
	int *pt = new int[64];
	for(int i=0; i<64; i++)	pt = 0;
	//Maximal number of factors with identical nonzero sparsity structure
	int maxfct = 1;
	//Actual matrix for the solution phase: 1 <= mnum <= maxfct
	int mnum = 1;
	//Defines the matrix type
	//11: real and unsymmetric matrix
	int mtype = 11;
	//Controls the execution of the solver
	int phase = 11;
	//Number of equations
	int n = 2;
	//Non-zero values of the coefficient matrix A
	//3  1	= A
	//0  0
	double *a = new double[3];
	a[0] = 3.0;
	a[1] = 1.0;
	a[2] = 0.0;
	//Row Index
	int *ia = new int[n+1];
	ia[0] = 1;
	ia[1] = 3;
	ia[2] = 4;
	//Columns
	int *ja = new int[2];
	ja[0] = 1;
	ja[1] = 2;
	ja[2] = 1;
	//Permutation vector of size n
	int *perm = new int;
	for(int i=0; i = 0;
	//Number of right-hand sides that need to be solved for
	int nrhs = 2;
	//Pass parameters to Pardiso
	int iparm[64];
	for(int i=0; i<64; i++)	iparm = 0;
	iparm[0] = 0;		// Solver default if iparm[0] = 0
	iparm[1] = 2;		// Fill-in reordering from METIS
						// Numbers of processors, value of OMP_NUM_THREADS
	iparm[2] = 1;		// Not in use
	iparm[3] = 0;		// No iterative-direct algorithm
	iparm[4] = 0;		// No user fill-in reducing permutation
	iparm[5] = 0;		// 0: Write solution into x / 1: The solver stores the solution on the righthand side b
	iparm[6] = 0;		// Not in use
	iparm[7] = 2;		// Max numbers of iterative refinement steps
	iparm[8] = 0;		// Not in use
	iparm[9] = 13;		// Perturb the pivot elements with 1E-13
	iparm[10] = 1;		// Use nonsymmetric permutation and scaling MPS
	iparm[11] = 0;		// Not in use
	iparm[12] = 1;		// Maximum weighted matching algorithm is switched-on (default for non-symmetric)
	iparm[13] = 0;		// Output: Number of perturbed pivots
	iparm[14] = 0;		// Not in use
	iparm[15] = 0;		// Not in use
	iparm[16] = 0;		// Not in use
	iparm[17] = -1;		// Output: Number of nonzeros in the factor LU
	iparm[18] = -1;		// Output: Mflops for LU factorization
	//iparm[19] = 0;		// Output: Numbers of CG Iterations
	//Message level information
	//0: Pardiso generates no output / 1: Pardiso prints statistical information to the screen
	int msglvl = 1;
	//Right-hand side
	// 5	= B
	// 6
	double *b = new double[n*nrhs];
	for(int i=0; i = 0.0;
	b[0] = 5.0;
	b[1] = 6.0;
	//Output if iparm(6)=0
	double *x =  new double[n*nrhs];
	//Error Indicator
	int error = 0;
	cout << "PARDISO PHASE: " << phase << endl;
	pardiso(pt, &maxfct, &mnum, &mtype, &phase, &n, a, ia, ja, perm, &nrhs, iparm, &msglvl, b, x, &error);
	cout << "Error = " << error << endl;
	cout << "b: ";
	for(int i=0; i << " ";
	cout << endl;
	cout << "x: ";
	cout << endl;
	phase = 22;
	cout << "b: ";
	cout << endl;
	cout << "x: ";
	cout << endl;
	phase = 33;
	cout << "b: ";
	cout << endl;
	cout << "x: ";
	cout << endl;
}[/cpp]
The matrix A is singular:
3 1
00
Respect to your question, always exist a submatrix of C that is not singular.
Alexander_K_Intel2
I've reproduced your issue, I will try to resolve it asap.
With best regards,
Alexander Kalinkin
Gennady_F_Intel
JBervel,
the fix of this problem available in the latest Update 6. See here the anounce of this release.
Please check the issue and let us know the results.
--Gennady
