Matrix Inversion LAPACKE_zsytri
Gianluca_G_
hello everyone,
I'm testing the inversion of a symmetric matrix, in order to do that, I wrote this code:
Complex[,] c = (Complex[,])a.Clone(); //I need to use it later
Complex[,] d = (Complex[,])a.Clone(); //I need to use it later
int n = a.GetLength(0);
int lda = n;
int info = 1;
int[] ipiv = new int;
info = MKLWrapper.LAPACKE_zsytrf(LAPACK_ROW_MAJOR, UPLO_U, n, c, lda, ipiv);
info = MKLWrapper.LAPACKE_zsytri(LAPACK_ROW_MAJOR, UPLO_U, n, c, lda, ipiv);
ipiv = new int;
info = MKLWrapper.LAPACKE_zsytrf(LAPACK_ROW_MAJOR, UPLO_L, n, d, lda, ipiv);
info = MKLWrapper.LAPACKE_zsytri(LAPACK_ROW_MAJOR, UPLO_L, n, d, lda, ipiv);
for (int i = 1; i <= a.GetLength(0); i++)
	  for (int j = 1; j <= a.GetLength(1); j++)
		    if (i > j)
			      c[i, j] = d[i, j];
This code works, but I'm not sure this is the right way to obtain my aim.
Is there anyone that can help me?
Thank you very much
Gianluca
Gianluca_G_
The solution is easy!
The inverted matrix of a symmetrical matrix is symmetrical too. So the right code is:
            int lda = n;
            int info = 1;
                    if (i > j)
                        c[i, j] = c[j, i];
            if (info == 0)
                return c;
            else
                return null;
Ying_H_Intel
Hi Gianluca G,
You are right, you can use get the inversion like that.   Thank you for sharing.
Ying
