7302 Discussions
Matrix Inversion using Lapack (DGETRF/DGETRI)
Neto__Conrado
I am trying to invert the following matrix using DGETRF and DGETRI
matrix =
  0.50E+12  0.00E+00 -0.30E+09  0.25E+12  0.00E+00  0.10E-02  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00
  0.00E+00  0.12E+08  0.00E+00  0.00E+00 -0.60E+07 -0.00E+00 -0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00
 -0.30E+09  0.00E+00  0.48E+06  0.00E+00 -0.00E+00 -0.00E+00  0.30E+09  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00
  0.25E+12  0.00E+00  0.00E+00  0.10E+13  0.00E+00 -0.00E+00  0.25E+12  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00
  0.00E+00 -0.60E+07 -0.00E+00  0.00E+00  0.12E+08 -0.00E+00  0.00E+00 -0.60E+07 -0.00E+00 -0.00E+00  0.00E+00  0.00E+00
  0.00E+00 -0.00E+00 -0.24E+06 -0.30E+09  0.00E+00  0.60E+04  0.00E+00 -0.00E+00 -0.24E+06  0.30E+09  0.00E+00  0.00E+00
  0.00E+00 -0.00E+00  0.30E+09  0.25E+12  0.00E+00 -0.00E+00  0.10E+13  0.00E+00 -0.30E+09  0.25E+12  0.00E+00  0.00E+00
  0.00E+00  0.00E+00  0.00E+00  0.00E+00 -0.60E+07 -0.00E+00  0.00E+00  0.12E+08  0.00E+00  0.00E+00 -0.60E+07 -0.00E+00
  0.00E+00  0.00E+00  0.00E+00  0.00E+00 -0.00E+00 -0.00E+00 -0.30E+09  0.00E+00  0.48E+06  0.00E+00 -0.00E+00  0.30E+09
  0.00E+00  0.00E+00  0.00E+00  0.00E+00 -0.00E+00 -0.00E+00  0.25E+12  0.00E+00  0.00E+00  0.10E+13  0.00E+00  0.25E+12
  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00 -0.10E-02  0.00E+00 -0.60E+07 -0.00E+00  0.00E+00  0.60E+07  0.00E+00
  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00 -0.10E-02  0.00E+00 -0.00E+00  0.30E+09  0.25E+12  0.00E+00  0.50E+12
however it says the matrix is numerically singular. However I can invert the matrix using excel/matlab with no problems
Does anyone have any idea why this is happening?
in the code below, the matrix is of size MJNT3xMJNT3 however I want to invert only the first NxN terms of S or Sinv.
I tried calling
CALL DGETRF(N, N, Sinv, N, ipiv, info)
CALL DGETRI(N, Sinv, N, ipiv, work, N, info)
it doesn't work. Then I tried a few other possibilities replacing the LDA in both DGETRF and DGETRI from N to MJNT3. and it didn't work either
I am not expert, so this is quite confusing to me.
the whole subroutine is given below:
      SUBROUTINE INVERT(S)
      INTEGER MJNT,MJNT3
      PARAMETER (MJNT=510,MJNT3=3*MJNT)
!     DECLARING GLOBAL VARIABLES
      COMMON /CLIST21/ N,NJ3,M,NMT,NJ,NRJ,NR
      INTEGER N,NJ3,M,NMT,NJ,NRJ,NR !21
!     DECLARING LOCAL VARIABLES
      INTEGER I,J !21
      REAL*8 S(MJNT3,MJNT3)
      REAL*8 Sinv(MJNT3,MJNT3)
      INTEGER, DIMENSION(size(Sinv,1)) :: ipiv   ! pivot indices
      INTEGER, PARAMETER :: dp = selected_real_kind(15, 307)
      real(dp), DIMENSION(size(Sinv,1)) :: work  ! work array for LAPACK
      INTEGER :: info
      EXTERNAL DGETRF
      EXTERNAL DGETRI
      ! Store S in Sinv to prevent it from being overwritten by LAPACK
      DO 10 I=1,N
      DO 20 J=1,N
      Sinv(I,J) = S(I,J)
20    CONTINUE
10    CONTINUE
      ! DGETRF COMPUTES AN LU FACTORIZATION OF A GENERAL M-BY-N MATRIX A
      ! USING PARTIAL PIVOTING WITH ROW INTERCHANGES.
      IF (info /= 0) THEN
          STOP 'MATRIX IS NUMERICALLY SINGULAR!'
      END IF
      ! DGETRI COMPUTES THE INVERSE OF A MATRIX USING THE LU FACTORIZATION
      ! COMPUTED BY DGETRF.
      IF (info /= 0) THEN
          STOP 'MATRIX INVERSION FAILED!'
      END IF
      DO 30 I=1,N
      DO 40 J=1,N
      S(I,J) = Sinv(I,J)
40    CONTINUE
30    CONTINUE
      PAUSE !to test
      RETURN
      END
Steve_Lionel
Please ask this in the MKL forum. It isn't a compiler question.
mecej4
As Steve wrote, this is a topic for the MKL forum.
Since SINV is not an N X N matrix, the 4th argument to DGETRF and the 3rd argument to DGETRI are incorrect. Since N is in a common block, you need to ensure that N is set to the correct value before the subroutine is called.
Rather than trying arbitrary values for arguments, please read the MKL/Lapack documentation and pass the correct arguments to DGETRF and DGETRI.
      program calls
      real*8 s(1530,1530)
      call invert(s)
      write(*,10)((s(i,j),j=1,12),i=1,12)
   10 format(12ES11.3)
      end program
      subroutine invert(s)
      integer mjnt,mjnt3
      parameter (mjnt=510,mjnt3=3*mjnt)
!     declaring global variables
      integer n
!     declaring local variables
      integer i,j !21
      real*8 s(mjnt3,mjnt3)
      real*8 sinv(mjnt3,mjnt3)
      integer, dimension(size(sinv,1)) :: ipiv   ! pivot indices
      integer, parameter :: dp = selected_real_kind(15, 307)
      real(dp), dimension(size(sinv,1)) :: work  ! work array for lapack
      integer :: info
      external dgetrf
      external dgetri
      n=12
      read(*,*)((s(i,j),j=1,n),i=1,n)
      ! store s in sinv to prevent it from being overwritten by lapack
      do 10 i=1,n
      do 20 j=1,n
      sinv(i,j) = s(i,j)
20    continue
10    continue
      ! dgetrf computes an lu factorization of a general m-by-n matrix a
      ! using partial pivoting with row interchanges.
      call dgetrf(n, n, sinv, mjnt3, ipiv, info)
      if (info /= 0) then
          stop 'matrix is numerically singular!'
      end if
      ! dgetri computes the inverse of a matrix using the lu factorization
      ! computed by dgetrf.
      call dgetri(n, sinv, mjnt3, ipiv, work, n, info)
      if (info /= 0) then
          stop 'matrix inversion failed!'
      end if
      do 30 i=1,n
      do 40 j=1,n
      s(i,j) = sinv(i,j)
40    continue
30    continue
      return
      end
Gennady_F_Intel
or look at the dgetrix.f  examples from mklroot/examples/lapackf/source directory and plus this link to the MKL Developer Reference - https://software.intel.com/en-us/onemkl-developer-reference-fortran-getri
