Memory Management with MKL
nansal
Hi there,
I have a serious problem with memory management of MKL. And it is essential for me to overcome to this problem.
In my Fortran language program (in Linux), I have one matrix with dimension of A(TRINATOM,TRINATOM) (TRINATOM=23826); that after running of the program, I have this message:
Fortcom: ERROR: myprog.for, Line 17: A common block or variable may not exceed 2147483647 bytes.
So I try to use memory management with MKL. First of all I introduced the matrix 'A' by POINTER instead of DIMENSION as bellow:
POINTER (A_PTR, A(23826,23826))
But after running, I have the same previous ERROR.
After that, I tried with:
POINTER A(:,:)
ALLOC_SIZE=4*2147483647
A=MKL_MALLOC(ALLOC_SIZE,128)
CALL dgetrf(NRED,NRED,A,TRINATOM,ipiv,info)
CALL MKL_FREEBUFFERS
CALL dgetrs('N',NRED,1,A,TRINATOM,ipiv,FRED,NRED,info)
ALLOCATED_BYTES=MKL_MEMSTAT(ALLOCATED_BUFFERS)
But I have this message:
Forrtl: Severe (408): fort (7): Attempt to use pointer A when it is not associated with a target.
I really appreciate your helps.
TimP
OK, some opinions, as I haven't tried anything like this. You will need 64-bit linux and MKL to deal with this. There is an example
http://www.intel.com/software/products/mkl/docs/WebHelp/support/spt_MemExample.html
about using MKL_MALLOC in Fortran, which would show you some of what you missed. The simplest way to go about it might be with an ALLOCATABLE array, not using MKL_MALLOC.
nansal
Quoting - tim18
I really appreciate your attention, Tim.
I have already checked my program with this example and think that I have not missed anything.
Also, I have applied the ALLOCATABLE array as bellow:
ALLOCATABLE A(:,:)
ALLOCATE (A(23826,23826))
After running the program at the line of ALLOCATE statement, I had this message
Forrtl: severe (179): cannot allocate array-overflow on array size calculation
Do you have any idea for this problem due to ALLOCATE statement?
Thank you again,
And I am really looking forward to any help.
TimP
Quoting - nansal
ALLOCATABLE A(:,:)
You need 64-bit integers to take advantage of 64-bit OS (23826_8, if you don't care about portability). You should also set up your ALLOCATE to display the ERRMSG when it fails.
