Memory in PARDISO
programmer85
I am brand new in MKL. I have two question:
1. is it possible to malloc dynamicly memory for doublecomplex structure ? I tried to use basic instructions like for double array (*double)malloc(N*sizeof(double)) or (double)malloc(N*sizeof(double)) and its few combinations but it does not work. I know that I can use doublecomplex, but what if N is not constant ?
2. How much data may be allocated for single matrix in PARDISO ? If I allocate small matrix everything is finem but if I allocate bigger matrix (such as 50 000 x50 000, with 2 000 000 of nonzeros) there is an alert :
STACK IS OVER FLOW, please help me !!!
Thank in advance,
Gennady_F_Intel
programmer85,
1)please try to by such way:
typedef struct{
double re;
double i;
}doublecomplex;
N = 50 000;
doublecomplex* aa = new doublecomplex ;
2)STACK IS OVER FLOW happened because of static arrays ...Please use only dynamic allocation.
Please let us know - if anyfurtherproblem- i will provide thetest case for you.
--Gennady
programmer85
Unfortunatelly,
using
N = 50 000;
An error ocurrs:
Error 1233 error: identifier "new" is undefined ...
Gennady_F_Intel
may be renaming *.c to *.cpp will help you
programmer85
...no it did not... any other ideas ?
Konstantin_A_Intel
1) "new" is C++, so "icpc" compiler should be used instead of "icc".
2) In order to make it with "icc", please make as follows:
doublecomplex* aa = (doublecomplex*)malloc(sizeof(doublecomplex*N);
Konstantin
