7303 Discussions
Memory increasing problem calling trigonometric transform routines.
zhangwei83
Hi all
I have some problems with calling trigonometric transform routines in MKL, here is the exact description of my
problem: In loops(up to more than 1,000,000),i need to call MKL trigonometric transform routines to calculate Fast
cosine fourier transform, but when running my problem, the memory is increasing continuously till the problem has
to stop.
My OS is Windows xp sp2, with Intel visual fortran 11.0 and MKL 10.0
The following subroutine is called in loops:
subroutine residual(mgh,ush)
use global
implicit none
integer i,j,nn,mgh
real*8 ush(0:nx(mgh),0:ny(mgh),2:3)
type(dfti_descriptor), pointer :: handle_c,handle_s
integer tt_type_c,tt_type_s,stat_s,stat_c
integer ipar_c(128),ipar_s(128)
real*8 dpar_c(5*max(ni,nj)/2+2),dpar_s(5*max(ni,nj)/2+2)
real*8 an(0:max(ni,nj)),qprime(0:max(ni,nj)),qdprime(0:max(ni,nj))
real*8 vx1(ni-1),vx2(ni-1),px(ni-1)
real*8 vy1(nj-1),vy2(nj-1),py(nj-1)
resi=0.
tt_type_c=1
tt_type_s=0
nn=nx(mgh)
do j=1,ny(mgh)-1
an(0:nn)=mid(0:nn,j,2)
call d_init_trig_transform(nn,tt_type_c,ipar_c,dpar_c,stat_c)
call d_commit_trig_transform(an(0:nn),handle_c,ipar_c,dpar_c,stat_c)
call d_forward_trig_transform(an(0:nn),handle_c,ipar_c,dpar_c,stat_c)
call free_trig_transform(handle_c,ipar_c,stat_c)
qprime(0:nn)=an(0:nn)*i_1(0:nn)
qprime(0)=0.0
qprime(nn)=0.0
call d_init_trig_transform(nn,tt_type_s,ipar_s,dpar_s,stat_s)
call d_commit_trig_transform(qprime(0:nn),handle_s,ipar_s,dpar_s,stat_s)
call d_backward_trig_transform(qprime(0:nn),handle_s,ipar_s,dpar_s,stat_s)
call free_trig_transform(handle_s,ipar_s,stat_s)
qdprime(0:nn)=an(0:nn)*i_2(0:nn)
call d_commit_trig_transform(qdprime(0:nn),handle_c,ipar_c,dpar_c,stat_c)
call d_backward_trig_transform(qdprime(0:nn),handle_c,ipar_c,dpar_c,stat_c)
vx1(1:nn-1)=qprime(1:nn-1)*xdon12(1:nn-1,mgh)
vx2(1:nn-1)=qprime(1:nn-1)*xdon32(1:nn-1,mgh)-qdprime(1:nn-1)*xdon1(1:nn-1,mgh)
call dgemv('n',nn-1,nn-1,1.0,pdx(1:nn-1,1:nn-1,mgh),nn-1,mid(1:nn-1,j,1),1,0.0,px,1)
resi(1:nn-1,j,1)=resi(1:nn-1,j,1)-beta*vx1(1:nn-1)
resi(1:nn-1,j,2)=resi(1:nn-1,j,2)-mid(1:nn-1,j,2)*vx1(1:nn-1)+vx2(1:nn-1)/re-px(1:nn-1)
enddo
call mkl_freebuffers()
end subroutine
As you can see, the forward and backward routines are called several times in the subroutine and the subroutine is
called in the main program for many times.
Could anyone tell me how to deal with this problem? Thanks a lot.
Sergey_G_Intel
First of all, thank you for using Intel MKL!
Could you please check and let me know what happens if you
1. put the line call mkl_freebuffers() inside the loop
2. put the calls to all init andcommit routines before the loopand the calls to all free routinesafter the loop
It would also be helpful for me to get a driver that runs your subroutine residual to see the growth of memory used. Could you provide it please?
-Sergey G
