I suspect that a memory leak happens in the subroutine DSS. I am using the latest version of MKL.
In order to verify this, I have also tested the source code 'dss_sym_f90.f90', which was included as an example in the MKL. I found that the subroutine DSS_DELETE does not deallocate all the relevant memory.
I have tried the measure suggested on the following webpage, but it did not work.
Please find the enclosed source code, which I have used to view the memory usage.
Thank you.
