Minimum working example for mkl_ddnscsr
Chris_W_8
Hi. Can anyone provide me with a minimum working example for mkl_ddnscsr? I have tried this so far
[cpp]#include <stdio.h>
#include <stdlib.h>
#include <mkl.h>
int main(int argc, char *argv[])
  MKL_INT info;
  MKL_INT m = 3; //Number of rows of A
  MKL_INT n = 4; //Number of columns of A
  MKL_INT nnz = 6; //Number of non zero elements
  MKL_INT job[6] = {0,0,1,2,nnz,1};
  double  *Acsr = (double *)  calloc(nnz, sizeof(double)  );
  MKL_INT *Aj   = (MKL_INT *) calloc(nnz, sizeof(MKL_INT) );
  MKL_INT *Ai   = (MKL_INT *) calloc(m+1, sizeof(MKL_INT) );
  double A[3][4] = {{1.,3.,0.,0.},{0.,0.,4.,0.},{2.,5.,0.,6.}};
  mkl_ddnscsr ( job, &m, &n, A[0], &m, Acsr, Aj, Ai, &info);
  for (int i=0; i< nnz; i++) {
    if (Acsr != 0) {
      printf( "column = %i, A = %f\n", Aj, Acsr );
  for (int i=0; i< m+1; i++) {
    printf("Ai[%i] = %i\n", i, Ai);
  return 0;
}[/cpp]
But it returns these results
[bash]column = 1, A = 1.000000
column = 2, A = 3.000000
column = 4, A = 4.000000
column = 1, A = 4.000000
column = 3, A = 2.000000
column = 4, A = 5.000000
Ai[0] = 1
Ai[1] = 3
Ai[2] = 4
Ai[3] = 7
[/bash]
If I play with the value for the lda I can almost get the correct result, however I believe this is as the manual suggests. I am on using Ubuntu 12.04 and Composer 2013.3.163 if that makes difference.
Chris
mecej4
You have obtained the CSR representation of AT rather than of A. The reason is that your array A, being a native 2-D array in C, is arranged in row-major order. The library routine expects column-major order, which is the order used for 2-D arrays in Fortran.
Gennady_F_Intel
also you can have a look at the mkl_ddnscsr example from the mkl's package: "mkl_install_dir\examples\spblasc\source\ dconverters.c"
Chris_W_8
Hey great. Thanks a lot guys. I have it working now. Both suggestions were very helpful. Now I can try to so some science. Thank you very much :-)
