Missing MKL_C.lib in 10.2.1 Download
geoluheorteyahoo_com
Was 10.2.1 supposed to have MKL_C.lib when downloaded? Was using that lib with 10.1.3 but found when moving to 10.2.1 that it is missing from the lib directory for IA32.
TimP
You could try the link advisor on the forum page so as to compare its suggestion with the libraries impled by the earlier mkl_c.lib. I guess, if you're looking at the Windows version, the mkl_c.lib wasn't explicit, unless the implied dlls could be determined by viewing the dependencies of the .exe.
ArturGuzik
Valued Contributor I
Following Tim's response you might also take a look at Gennady's reply here.
A.
Gennady_F_Intel
Quoting - ArturGuzik
A.
one more comment: What do you need to do in this case?
You need to relink your application accordingly the recommended linking line.
--Gennady
