7298 Discussions
Missing function ?lascl2 in MKL reelase 10.3 Update 11
rohitspandey
Hi All,
As per MKL documnetation the library support the function ?lascl2. And the function definition shall be contained in Composer XE 2011 SP1\\mkl\\include\\mkl_lapack.h.
I cannot find it (I can only find ?lascl) on my installation. I have licensed version of MKL library.
Is there a reason we don’t have the complete set? Is there a way to download this specific missing module?
I do see the definition in the mkl_rt.lib when i serach it using text editor.So it seems got missed in header definition. Kindly provide the solution.
Rohit
Gennady_F_Intel
Rohit, thanks for the issue. we missed to add this API to the header files.
we will fix it the next update.
--Gennady
Gennady_F_Intel
as a temporarily workaroud - please add  manually the declaration of this API to the mkl_lapack.h and then you can compile and link your application.
rohitspandey
Kindly share the API signature. We tried using some of them based on the API definition in document. it didnt worked.
#r
Rohit
barragan_villanueva_
Valued Contributor I
void CLARSCL2( const MKL_INT* m, const MKL_INT* n, const float* d, MKL_Complex8* x,
               const MKL_INT* ldx );
void CLARSCL2_( const MKL_INT* m, const MKL_INT* n, const float* d, MKL_Complex8* x,
void clarscl2( const MKL_INT* m, const MKL_INT* n, const float* d, MKL_Complex8* x,
void clarscl2_( const MKL_INT* m, const MKL_INT* n, const float* d, MKL_Complex8* x,
void CLASCL2( const MKL_INT* m, const MKL_INT* n, const float* d, MKL_Complex8* x,
void CLASCL2_( const MKL_INT* m, const MKL_INT* n, const float* d, MKL_Complex8* x,
void clascl2( const MKL_INT* m, const MKL_INT* n, const float* d, MKL_Complex8* x,
void clascl2_( const MKL_INT* m, const MKL_INT* n, const float* d, MKL_Complex8* x,
void DLARSCL2( const MKL_INT* m, const MKL_INT* n, const double* d, double* x,
void DLARSCL2_( const MKL_INT* m, const MKL_INT* n, const double* d, double* x,
void dlarscl2( const MKL_INT* m, const MKL_INT* n, const double* d, double* x,
void dlarscl2_( const MKL_INT* m, const MKL_INT* n, const double* d, double* x,
void DLASCL2( const MKL_INT* m, const MKL_INT* n, const double* d, double* x,
void DLASCL2_( const MKL_INT* m, const MKL_INT* n, const double* d, double* x,
void dlascl2( const MKL_INT* m, const MKL_INT* n, const double* d, double* x,
void dlascl2_( const MKL_INT* m, const MKL_INT* n, const double* d, double* x,
void SLARSCL2( const MKL_INT* m, const MKL_INT* n, const float* d, float* x,
void SLARSCL2_( const MKL_INT* m, const MKL_INT* n, const float* d, float* x,
void slarscl2( const MKL_INT* m, const MKL_INT* n, const float* d, float* x,
void slarscl2_( const MKL_INT* m, const MKL_INT* n, const float* d, float* x,
void SLASCL2( const MKL_INT* m, const MKL_INT* n, const float* d, float* x,
void SLASCL2_( const MKL_INT* m, const MKL_INT* n, const float* d, float* x,
void slascl2( const MKL_INT* m, const MKL_INT* n, const float* d, float* x,
void slascl2_( const MKL_INT* m, const MKL_INT* n, const float* d, float* x,
void ZLARSCL2( const MKL_INT* m, const MKL_INT* n, const double* d, MKL_Complex16* x,
void ZLARSCL2_( const MKL_INT* m, const MKL_INT* n, const double* d, MKL_Complex16* x,
void zlarscl2( const MKL_INT* m, const MKL_INT* n, const double* d, MKL_Complex16* x,
void zlarscl2_( const MKL_INT* m, const MKL_INT* n, const double* d, MKL_Complex16* x,
void ZLASCL2( const MKL_INT* m, const MKL_INT* n, const double* d, MKL_Complex16* x,
void ZLASCL2_( const MKL_INT* m, const MKL_INT* n, const double* d, MKL_Complex16* x,
void zlascl2( const MKL_INT* m, const MKL_INT* n, const double* d, MKL_Complex16* x,
void zlascl2_( const MKL_INT* m, const MKL_INT* n, const double* d, MKL_Complex16* x,
Please check and let us know how they work
rohitspandey
Thanks!!
#r
Rohit
Gennady_F_Intel
Hello Rohit, pls see the fix the problem in version 11.0 update 1. --Gennady
