7303 Discussions
Need help to convert codes that used guide library
Yu-ching_Tong
I am trying to build codes that were written for older Intel Compiler that use the -lguide but I have the Intel Composer XE for Linux and is not compiling. Is it possible to just change the library to use open mp in the linker? Or I need to change the compiler option while compiling? Or I need to change the code?
TimP
-liomp5 should take care of everything in -lguide, if you don't have other version dependencies. If you're simply using OpenMP, setting the compiler option -parallel or -openmp for the link step implies -liomp5 -lpthread, just as it formerly implied -lguide -lpthread.
TimP
VipinKumar_E_Intel
You may also take a look at the link line advisor tool
http://software.intel.com/en-us/articles/intel-mkl-link-line-advisor/
--Vipin
