No speedup of cluster_sparse_solver beyond 32 cpus
Ferris_H_
My cluster has 16 cpus/node. My matrix is symmetric positive definite and size is ~2 million by 2 million with ~4 million non-zero entries. My factorization times are:
16 cpus -  84 seconds
32 cpus - 44 seconds
48 cpus - 48 seconds ?!
The factorization takes longer with 48 cpus compared to 32 cpus.
I have tried with smaller matrix and get the same results. There is no speedup beyond 32 cpus. Is this a known limitation of cluster_sparse_solver or a problem with my cluster? If a cluster problem, any suggestions on how can I narrow down the bottleneck?
Gennady_F_Intel
Ferris, could you check the scalability with larger problem size?
Ferris_H_
Unfortunately, I do not have any larger matrixes to test . The size I am testing is around the largest I would see in my area. Are there any public benchmark matrixes I could download to test? If not , I can create an example code that reads in my matrix for you to test on your cluster.
Ferris_H_
I created an example file that can reproduce the issue. Download cl_solver_sym_sp_0_based_c.c from here:
https://www.dropbox.com/s/ndkzi9zojxuh1xo/cl_solver_sym_sp_0_based_c.c?dl=0
Edit all the occurences of *.txt to the path where the files are on your system.
ia, ja, a and b data in text files are all here:
https://www.dropbox.com/s/3dkhbillyso03kc/ia_ja_a_b_data.tar.gz?dl=0
Curious what kind of performance improvement you get when running with MPI on 16, 32, 48, and 72 cpus!
Gennady_F_Intel
Ferris, do you have access to the 64 cores system? i am currently not,  if you have, could you please try and give us the results? The scalability may be different if the number of nodes will be power of 2.
Ferris_H_
Hi Gennady,
As requested, I solved my model on a larger 4-node 60 core cluster with 15 cores/node each. Below are the factorization times:
15 cores - 70 seconds
30 cores - 41 seconds
45 cores - 42 seconds
60 cores - 36 seconds
So seems there is some improvement when the number of nodes is 4. But with 3 nodes it shows same solve times as 2 nodes. Does the number of nodes always have to be a power of 2? Or could there be some problem with my cluster?
