Numpy: LAPACK and BLAS libraries not found
Hilder_Pereira
Hello!
I have installed the MKL 10.3.7.256 (64 bits) on my Linux Slackware and now, I want to install the numpy and scipy packages.
But, when I try to make this, the LAPACK and the BLAS libraries are not found.
I'm trying to install the numpy following this Numpy User Note (http://software.intel.com/en-us/articles/numpy-user-note/)
I received these warnings when I try to compile:
"Running from numpy source directory./root/python/numpy-1.6.1/numpy/distutils/system_info.py:1414: UserWarning:
Atlas (http://math-atlas.sourceforge.net/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [atlas]) or by setting
the ATLAS environment variable.
warnings.warn(AtlasNotFoundError.__doc__)
/root/python/numpy-1.6.1/numpy/distutils/system_info.py:1423: UserWarning:
Blas (http://www.netlib.org/blas/) libraries not found.
numpy/distutils/site.cfg file (section [blas]) or by setting
the BLAS environment variable.
warnings.warn(BlasNotFoundError.__doc__)
/root/python/numpy-1.6.1/numpy/distutils/system_info.py:1426: UserWarning:
Blas (http://www.netlib.org/blas/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [blas_src]) or by setting
the BLAS_SRC environment variable.
warnings.warn(BlasSrcNotFoundError.__doc__)
/root/python/numpy-1.6.1/numpy/distutils/system_info.py:1330: UserWarning:
/root/python/numpy-1.6.1/numpy/distutils/system_info.py:1341: UserWarning:
Lapack (http://www.netlib.org/lapack/) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
warnings.warn(LapackNotFoundError.__doc__)
/root/python/numpy-1.6.1/numpy/distutils/system_info.py:1344: UserWarning:
Lapack (http://www.netlib.org/lapack/) sources not found.
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
warnings.warn(LapackSrcNotFoundError.__doc__)
/root/python/numpy-1.6.1/numpy/distutils/command/config.py:40: DeprecationWarning:
Usage of try_run is deprecated: please do not
use it anymore, and avoid configuration checks
involving running executable on the target machine.
DeprecationWarning)
and these messages:
"F2PY Version 2
blas_opt_info:
blas_mkl_info:
libraries mkl_intel_lp64,mkl_intel_thread,lmkl_core not found in /opt/intel/composer_xe_2011_sp1.7.256/mkl/lib/intel64/
NOT AVAILABLE
atlas_blas_threads_info:
Setting PTATLAS=ATLAS
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib64
libraries ptf77blas,ptcblas,atlas not found in /usr/lib64
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib64
libraries f77blas,cblas,atlas not found in /usr/lib64
NOT AVAILABLE
blas_info:
libraries blas not found in /usr/local/lib64
libraries blas not found in /usr/lib64
NOT AVAILABLE
blas_src_info:
NOT AVAILABLE
NOT AVAILABLE
lapack_opt_info:
lapack_mkl_info:
mkl_info:
NOT AVAILABLE
NOT AVAILABLE
atlas_threads_info:
libraries lapack_atlas not found in /usr/local/lib64
libraries lapack_atlas not found in /usr/lib64
numpy.distutils.system_info.atlas_threads_info
NOT AVAILABLE
atlas_info:
numpy.distutils.system_info.atlas_info
NOT AVAILABLE
lapack_info:
libraries lapack not found in /usr/local/lib64
libraries lapack not found in /usr/lib64
NOT AVAILABLE
lapack_src_info:
NOT AVAILABLE
NOT AVAILABLE
And I don't know why the compiler are searching the libs in the /usr directory.
Somebody could help, please?
mecej4
You are trying to build a package with substitutions (MKL) for some packages (Atlas, Lapack, BLAS). The default build (makefile, configure, etc.) knows nothing about your intentions, and will not work without your making suitable changes.
Look for places in the Makefile where you can specify alternative names and locations for libraries, and see if you can make changes there to make the package work with MKL.
TimP
The diagnostics quoted above do indicate that the default location for the MKL libraries was searched, but possibly not for the correct library names. Either the link advisor tool or ls will show you the exact names, and verify whether you may have changed the install path.
Hilder_Pereira
Mecej4,
I think the locations where the compiler will search the libs is specified by the file site.cfg
and my file have:
"[mkl]
library_dirs = /opt/intel/composer_xe_2011_sp1.7.256/mkl/lib/intel64/
include_dirs = /opt/intel/composer_xe_2011_sp1.7.256/mkl/include/
mkl_libs = mkl_intel_lp64,mkl_intel_thread,lmkl_core
lapack_libs = mkl_lapack_ilp64
like I saw in the Numpy User Note (http://software.intel.com/en-us/articles/numpy-user-note/ end of page).
Am I wrong?
Hilder_Pereira
When I list the directory I have:
$ ls /opt/intel/composer_xe_2011_sp1.7.256/mkl/lib/intel64/
libmkl_avx.so* libmkl_intel_sp2dp.so*
libmkl_blacs_ilp64.a libmkl_intel_thread.a
libmkl_blacs_intelmpi_ilp64.a libmkl_intel_thread.so*
libmkl_blacs_intelmpi_ilp64.so* libmkl_lapack95_ilp64.a
libmkl_blacs_intelmpi_lp64.a libmkl_lapack95_lp64.a
libmkl_blacs_intelmpi_lp64.so* libmkl_mc.so*
libmkl_blacs_lp64.a libmkl_mc3.so*
libmkl_blacs_openmpi_ilp64.a libmkl_p4n.so*
libmkl_blacs_openmpi_lp64.a libmkl_pgi_thread.a
libmkl_blacs_sgimpt_ilp64.a libmkl_pgi_thread.so*
libmkl_blacs_sgimpt_lp64.a libmkl_rt.so*
libmkl_blas95_ilp64.a libmkl_scalapack_ilp64.a
libmkl_blas95_lp64.a libmkl_scalapack_ilp64.so*
libmkl_cdft_core.a libmkl_scalapack_lp64.a
libmkl_cdft_core.so* libmkl_scalapack_lp64.so*
libmkl_core.a libmkl_sequential.a
libmkl_core.so* libmkl_sequential.so*
libmkl_def.so* libmkl_solver_ilp64.a
libmkl_gf_ilp64.a libmkl_solver_ilp64_sequential.a
libmkl_gf_ilp64.so* libmkl_solver_lp64.a
libmkl_gf_lp64.a libmkl_solver_lp64_sequential.a
libmkl_gf_lp64.so* libmkl_vml_avx.so*
libmkl_gnu_thread.a libmkl_vml_def.so*
libmkl_gnu_thread.so* libmkl_vml_mc.so*
libmkl_intel_ilp64.a libmkl_vml_mc2.so*
libmkl_intel_ilp64.so* libmkl_vml_mc3.so*
libmkl_intel_lp64.a libmkl_vml_p4n.so*
libmkl_intel_lp64.so* locale/
libmkl_intel_sp2dp.a
and, for example, the message
mkl_info:
says that the libs mkl_intel_lp64 and mkl_intel_thread was not found (but they are in the directory, it's just see the output of ls...)
What can I do?
Thank you very much for the atention!
TimP
Check that the libraries are referenced by correct spellings;
-lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread
would be expanded in normal ld fashion to the .so libraries; if linking the static libraries, the specification passed to ld must be in accordance with the link advisor (full path names fully spelled out, with the --begin-group .... --end-group directives included).
The intel_thread libraries also introduce dependency on libiomp5 and libpthread.
mecej4
Sorry, I had not bothered to look at the Numpy User Note link that you provided. This is one of those instances where I had to learn by doing. I downloaded the current NumPy source distribution from Sourceforge and built the package on OpenSuse 11.4 X64. Only a minor correction was needed to build the 64-bit version. Please see the comment that I added to the User Note page.
Simply put, change
to
lapack_libs =
in file site.cfg.
Hilder_Pereira
macej4,
I made it and it didn't work
I received the same messages and warnings.
mecej4
That's surprising. What are the compiler, kernel and OS versions on your system?
Hilder_Pereira
The comipler version is 11.0
and the OS is Slackware 13.1.0 (with kernel 2.6.33.4).
The processor is a x86_64 Intel Core2 Quad CPU Q6600 @ 2.40GHz
mecej4
The compiler version number that you just gave (11.0) is not consistent with the directory name given earlier (/opt/intel/composer_xe_2011_sp1.7.256/mkl/lib/intel64/ ).
If you have more than one version of the compiler and more than one version of MKL it is necessary to use a matching combination, since the MKL libraries were changed considerably from those in compiler version 11.0 to those in 12.1.
TimP
While it's certainly possible to use MKL and Intel compiler versions which weren't issued together, one of the value improvements in the integrated compiler and MKL release is the possibility of sourceing a single script to set up the combined path environment. When your results aren't consistent with the use of a single combined compiler/library release, nor with your description of versions you intended, it's difficult to discount the possibility that the reported problems arise from such inconsistencies.
Gennady_F_Intel
that's correct: Compiler Version 11.0 contains the version of MKL 10.1. You can find all required binaries ( for example for 64bit ) for this version in the following directory:
/opt/intel/Compiler/11.0/084/mkl/lib/em64t
please pay attention at the name of this folder. This is not intel64 but em64t.
Hilder_Pereira
I have just one version of mkl and icc.
But, could you talk about this inconsistence with the directory name?
