Numpy + MKL only using 1 core of cpu on Ubuntu 16.04
xiao__yuanzheng
I am using Ubuntu 16.04 on my pc with "Intel® Core™ i7-7700K CPU @ 4.20GHz × 8".
My numpy and scipy only use one cpu when I try to do some element calculation for my numpy ndarray.
Something like:
numpy.power(matrix, 1.5)
I compiled the numpy and scipy following https://software.intel.com/en-us/articles/numpyscipy-with-intel-mkl?page=1
The numpy configurations are as following.
blas_opt_info:
    include_dirs = ['/opt/intel/compilers_and_libraries_2018/linux/mkl/include']
    library_dirs = ['/opt/intel/compilers_and_libraries_2018/linux/mkl/lib/intel64']
    define_macros = [('SCIPY_MKL_H', None), ('HAVE_CBLAS', None)]
    libraries = ['mkl_rt', 'pthread']
lapack_opt_info:
blas_mkl_info:
lapack_mkl_info:
I tried to modify environment variables like MKL_NUM_THREADS, OMP_NUM_THREADS, MKL_DOMAIN_NUM_THREADS, MKL_DYNAMIC, but they do nothing to my situation.
Thanks for your help.
xiao__yuanzheng
May I bring some more information.
The intel precompiled python runs well in my computer with multicores.
And the numpy I built can also do matrix product using multicores, but for element-wise product only one core is going to use (intel python will use at least 3).
Any suggestions? Thanks.
Ying_H_Intel
Hi Yuanzheng,
​Your observation give the hint for the answer of your question :)
​The build Numpy, Scipy with MKL is  based on  configuration:
So it adopts  part of MKL,   here CBLAS function  http://www.netlib.org/blas/​, which only have functions like matrix product gemm, matrix*vector etc. It don't include element-wise functions.  So you can't see MKL acceleration or multi-core for such operation in your build.
And Intel distributed Python did more optimization,  including MKL, DAAL, vector math, multithreading etc.  So you will see more performance benefits .
Best Regards
​Ying
xiao__yuanzheng
Hi Ying,
Do you have any suggestions for how to build numpy/scipy with those optimization functions?
Ying_H_Intel
Hi Yuanzheng,
​What i can suggest,
maybe easier way , to use Intel distributed Python, which is free and compatible with other conda package.
second way, do change the numpy/scipy source code manually , for example change their Vector implementation with MKL VML function etc. As Intel python developer did.
​third way, specific for your project,  for example, evaluate the hot functions list you will use, then manually optimize them by your function to replace the numpy/scipy implementation.
​Best Regards,
​Ying
