7303 Discussions
OneAPI 2025.3.0 Installer Won't Integrate with Visual Studio 2026
craigpod
Visual Studio 2026 has been released. The OneAPI 2025.3.0 Installer will not integrate with it and displays an error message saying the Visual Studio 2022 environment is not available. Can you help by providing instructions for a work around i can use until the installer is updated.
Fengrui
According to the system requirements of oneMKL, Visual Studio 2026 (not listed/tested) is not guaranteed to be working.
graff58
When will a VS 2026 Community compatible version be available? Thank you.
auaz
same issue here, would like to use Visual studio 2026 but there is no oneAPI working with it. appreciate if you provide an ETA for it.
Fengrui
Hi all,
We are working on an oneAPI patch release 2025.3.1 to support VS 2026. It is scheduled to launch soon.
Fengrui
Andrew_Smith
Valued Contributor I
I see 2025.3.2 is out and supports VS 2026
thismarkjohnson
oneAPI 2025.3 doesn’t support Visual Studio 2026 yet — the installer only integrates with VS 2022. There’s no real workaround other than installing VS 2022 side-by-side for now or using the command-line compilers without VS integration until Intel updates the installer.
Andrew_Smith
graff58
Hi all; I have installed the version 2025.3.1.35_offline (2025.3.2 is not showed for download) after updating VS2026 to latest version and running the "Intel Driver & Support Assistant"; the installation was OK on WIN11 PRO and VS2026 was recognized; then setvars.bat was executed as prescribed; after reboot VS2026 does not show in the "Extensions" tab  any "Intel" submenu but new three menu items in the main bar were added, namely: "Open Intel Advisor", "Open Intel VTune Profiler" and "Configure Analysis with Intel VTune Profiler"; no link to "Create New Intel oneAPI Project", "oneAPI Options..."  and "Browse Intel oneAPI Samples..." is showed as in VS2022.
Anyway in a new c++ project the item "Intel(R) Performance Libraries" under the "Configuration Properties" Property Pages is correctly added showing the same options (say IPP TPP and so on) of the item "Intel Libraries for oneAPI" in VS2022.
Conversely I did not found any "samples" folder to check the installation. Please reply if someone got a reliable and complete installation with samples.
Thank you very much.
Guido
graff58
Everything seems to work fine; downloaded from github the basic sample vect_add and compiled (Platform Toolset: Intel C++ Compiler 2025 instead of v154). Thank you again to all the staff.
Guido.
