OpenMP linking error
matthew_h
We're experiencing some linking problems using the MKL Math Library 8.1 with MSVC++ 2005. Our application uses OpenMP. The link fails, complaining that _omp_get_thread_num is multiply defined in vcompd.lib and libguide.lib. It doesn't seem right that libguide.lib should define omp_get_thread_num. Any ideas?
Matt Hartloff
cpickeri
Almost a year later and I'm not sure if this is the correct solution or not... but I linked against libguide40.lib instead of libguide.lib and that seemed to fix the problem.
