7303 Discussions
PARDISO - Invalid Address specified to RtlFreeHeap
d_shor
happens even in the simple pardiso_sym_c.c example, every few runs.
happened every run with a read larger problem.
on vs2005
both on core 2 and p4p
the libs used are
#pragma
comment (lib,"mkl_intel_c_dll.lib")
#pragma
comment (lib,"mkl_core_dll.lib")
#pragma
comment (lib,"libguide40.lib")
//#pragma comment (linker,"/NODEFAULTLIB:libguide40.lib")
//#pragma comment (linker,"/NODEFAULTLIB:libguide.lib")
//#pragma comment (lib,"libiomp5mt.lib")
#pragma
comment (lib,"mkl_intel_thread_dll.lib")
#pragma
comment (lib,"mkl_solver.lib")
output:
solver.exe': Loaded 'C:Program FilesIntelMKL10.0.2.019ia32inmkl_p4p.dll', Binary was not built with debug information.
'solver.exe': Loaded 'C:Program FilesIntelMKL10.0.2.019ia32inmkl_def.dll', Binary was not built with debug information.
'solver.exe': Loaded 'C:Program FilesIntelMKL10.0.2.019ia32inlibimalloc.dll', No symbols loaded.
'solver.exe': Unloaded 'C:Program FilesIntelMKL10.0.2.019ia32inlibimalloc.dll'
'solver.exe': Loaded 'C:Program FilesIntelMKL10.0.2.019ia32inmkl_lapack.dll', Binary was not built with debug information.
The thread 'Win32 Thread' (0xc6c) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0x86c) has exited with code 0 (0x0).
HEAP[solver.exe]: Invalid Address specified to RtlFreeHeap( 00370000, 00372E40 )
Windows has triggered a breakpoint in solver.exe.
This may be due to a corruption of the heap, and indicates a bug in solver.exe or any of the DLLs it has loaded.
The output window may have more diagnostic information
The program '[3628] solver.exe: Native' has exited with code 0 (0x0).
second problem in using the libiomp5mt.lib threading lib
with linker settings
#pragma
#pragma
//#pragma comment (lib,"libguide40.lib")
#pragma
#pragma
#pragma
#pragma
#pragma
I still get this error
C:Program FilesIntelMKL10.0.2.019examplessolversourcesolverRelease>solv
er.exe
OMP abort: Initializing libiomp5mt.lib, but found libguide40.lib already initial
ized.
This may cause performance degradation and correctness issues.
Set environment variable KMP_DUPLICATE_LIB_OK=TRUE to ignore
this problem and force the program to continue anyway.
Please note that the use of KMP_DUPLICATE_LIB_OK is unsupported
and using it may cause undefined behavior.
For more information, please contact Intel Premier Support.
rbarron
I reported the firstissue to Intel Premier support back in January.
I saw the samebehaviorin differentprograms using LAPACK or DFTI.
The warning occurs only when running under VS2005 debugger, and there
seems to be no other consequence -- my program performs correctly.
In March they notified me that afix is targeted for update 3,
which would be the next release afterMKL 10.0.2.019.
