7303 Discussions
PARDISO OOC temp files .sin and .sle are not deleted
xian-zhong_guous_cd-
I notice PARDISO OOC temp files .sin and .sle are not deleted. I use default MKL_PARDISO_OOC_KEEP_FILE which is 1 and other files are indeed deleted excpet those two. How to delete those two?
Alexander_K_Intel2
Which version of MKL do you use?
With best regards,
Alexander Kalinkin
The local (internal) PARDISO version is 103000115.
Gennady_F_Intel
please check with the latest 10.3 update 5 or 6 version of MKL. We have fixed such problem there.
here is the link to the 10.3 bug fix list
I tried 10.3 update 6 but got a Divid by zero error:
Error
A floating point exception has occured: floating point exception[Divid by zero] ...
I also notice the PARDISO log file shows the same local (internal) PARDISO version
The local (internal) PARDISO version is : 103000115
Alexander_K_Intel2
Are you checked correctness of initial matrix by matrix checker? If yes, could you attached your matrix here to reproduce your problem on our side?
With best regards,
Alexander Kalinkin
I've attached the matrix (in triplet 1-based format, with first line = order of matrix and the second line = nonber of nonzeros) and PARDISO log file.
I can solve this matrix using 10.3.1 without any problem.
Gennady_F_Intel
Did You use the default settings of iparm array or any specific settings were used?
