PARDISO for shotgun pattern sparse matrix
jaewonj
MKL 10.2.4 PARDISO with default settings (mtype = 11)
1) hangs at phase 22 on 64-bit Windows (8-core Xeon E5410 @ 2.33GHz)
2) hangs at phase 11 on 64-bit Linux (8-core Xeon X5560 @ 2.80GHz)
3) produces a wrong solution on 64-bit Linux (Core 2 6600 @ 2.40GHz)
Matrix attached (700-by-700, real unsymmetric, 98709 nz)
Gennady_F_Intel
Jewonj,
how about the others iparm[64]. Are they default?
--Gennady
Gennady_F_Intel
Yes, the problem has been reproduced on our side.Thanks for your problem you raised.
This issue has been submitted to our internal development tracking database for further investigation, we will inform you once a new update becomes available.
Here is a bug tracking number for your reference:DPD200088582.
--Gennady
