7303 Discussions
PARDISO gets stuck in num. factorization for a general complex matrix
rbunger
New Contributor II
PARDISO gets stuck in the numerical factorization step, for a general complex matrix. The matrix is too big to upload it (43 MB 7z archive).
OneAPI versions: 2025.3.0 and 2025.3.1
Rainer
rbunger
New Contributor II
Update: I had to upload the matrix elsewhere. Intel has confirmed a bug and the fix will be in the 2026.0 release. Meanwhile two fixes are proposed:
1) use iparm[23]=1,
2) if there are even number of NUMA nodes, you could use spread-type binding by "OMP_PLACES=cores OMP_PROC_BIND=spread".
Many thanks to the Intel team & kind regards,
Rainer
rbunger
New Contributor II
1) use iparm[23]=1,
Rainer
rbunger
New Contributor II
Option 2) has quite a large impact on the performance, in my case
Fengrui
Thanks again for reporting this issue. The fix is available in the latest 2026.0 release. Please check.
Fengrui
rbunger
New Contributor II
Many thanks for the reminder. I have already performed tests and up to now everything is perfectly stable. Many thanks for your efforts!
Rainer
