7300 Discussions
PARDISO reordering: incorrect description perm() array in the MKL manual
Sergey_S_1
Hi! I want to use own reordering in PARDISO. From manual I see following description of perm() array:  “Let A be the original matrix and C = P*A*PT be the permuted matrix. Row (column) i of A is the perm(i) row (column) of C.” Unfortunately, I got incorrect results, i.e. incorrect number of nonzero elements in L factors. After investigation, I found out that description of perm() array is incorrect. User should to set inversion of permutation instead permutation. I.e. “Row (column) i of C is the perm(i) row (column) of A.” Could you clarify, I am right or not?
P.S. Test case has been attached.
Sergey Solovev
Gennady_F_Intel
Hi Sergey,
the problem is reproduced and at the first glance it looks like the documentation's problem - the description should be slightly changed accordingly. we will check the behavior again and let you know.
--Gennady
Sergey_S_1
Hi Gennady,
Thank you for quick response!
Sergey Solovev
Gennady_F_Intel
Sergey, pls check the updated doc in the latest 11.0 update3. regards, Gennady
Sergey_S_1
Gennady, I have checked the fix. All is OK, thank you and MKL support team!
