PARDISO reproducibility
nedialk
For numerical reproducibility we need to set iparm[33] > 0 before the symbolic factorization, and this iparm cannot be changed after.
Is there a way to request reproducibility for a particular phase of the solving. E.g. how to request that only the numerical factorization is reproducible? That is I want to do e.g.
iparm[33] = 4;
iparm[33] = 0
Thank you.
ShanmukhS_Intel
Intel® oneAPI Math Kernel Library PARDISO reads the value of iparm[33] during the analysis phase (phase 1), so it cannot be changed later.
Optimal number of OpenMP threads for conditional numerical reproducibility (CNR) mode.
0*
CNR mode for Intel® oneAPI Math Kernel Library PARDISO is enabled only if it is enabled for
Intel® oneAPI Math Kernel Library using the functionality described inSupport Functions for CNRand the in-core version is used.
Intel® oneAPI Math Kernel Library  PARDISO determines the optimal number of OpenMP threads automatically, and produces numerically reproducible results regardless of the number of threads.
>0
CNR mode is enabled for Intel® oneAPI Math Kernel Library
PARDISO if in-core version is used and the optimal number of OpenMP threads for
Intel® oneAPI Math Kernel Library  PARDISO to rely on is defined by the value of
Iparm [33]. You can use iparm[33]to enable CNR mode independent from other
Intel® oneAPI Math Kernel Library domains. To get the best performance, set
iparm[33] to the actual number of hardware threads dedicated for
Intel® oneAPI Math Kernel Library PARDISO. Setting iparm[33] to fewer OpenMP threads than the maximum number of them in use reduces the scalability of the problem being solved. Setting iparm[33]
to more threads than are available can reduce the performance of Intel® oneAPI Math Kernel Library PARDISO.
Could you elaborate a bit regarding why iparam[33] Is required to change in your case.
Shanmukh.SS
nedialk
I wanted to figure out which part of the solution process causes the different results I am getting. I was hoping to turn on and off
this parameter for the various parts of the solving.
Ned
ShanmukhS_Intel
Kindly refer the below link for the usage of iparm[33] and various other iparm parameters.
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/sparse-solver-routines/onemkl-pardiso-parallel-direct-sparse-solver-iface/pardiso-iparm-parameter.html
You cannot change the iparm[33] parameter later , because Intel® oneAPI Math Kernel Library PARDISO reads the value of iparm[33] during the analysis phase (phase 1)
Intel® oneAPI Math Kernel Library PARDISO uses C random number generator facilities during the analysis phase (phase 1)
You must take these precautions to get numerically reproducible results:
Do not alter the states of the random number generators.
Do not run multiple instances of Intel® oneAPI Math Kernel Library PARDISO in parallel in the analysis phase (phase 1).
In addition, Could you please share us a sample reproducer so that we could try it at our end?
Shanmukh.SS
ShanmukhS_Intel
Reminder:
Has the information provided helped? Is your issue resolved?
Kindly let us know if we could close this thread at our end.
Shanmukh.SS
ShanmukhS_Intel
We haven't heard back from you. We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shanmukh.SS
nedialk
