PARDISO unsymmetric only using 1 processor
xian-zhong_guous_cd-
I have a SPD matrix. If I solve it as SPD (type=2), PARDISO uses 8 processors. But if I solve it as unsymmetric, PARDISO only uses 1 processor. (both logs are enclosed)
Symmetric log:
N=119433
ooc_max_core_size got by Env = 20000
The file ./pardiso_ooc.cfg was not opened
=== PARDISO is running in In-Core mode, because iparam(60)=1 and there is enough RAM for In-Core ===
================ PARDISO: solving a symm. posit. def. system ================
Summary PARDISO: ( reorder to reorder )
Times:
Time fulladj: 0.014256 s
Time reorder: 0.927871 s
Time symbfct: 0.102223 s
Time parlist: 0.013512 s
Time malloc : 0.018803 s
Time total : 1.149216 s total - sum: 0.072551 s
Statistics:
< Parallel Direct Factorization with #processors: > 8
< Numerical Factorization with BLAS3 and O(n) synchronization >
< Linear system Ax = b>
#equations: 119433
#non-zeros in A: 821520
non-zeros in A (%): 0.005759
#right-hand sides: 1
< Factors L and U >
#columns for each panel: 64
#independent subgraphs: 0
< Preprocessing with state of the art partitioning metis>
#supernodes: 55725
size of largest supernode: 605
number of nonzeros in L 14908033
number of nonzeros in U 1
number of nonzeros in L+U 14908034
Percentage of computed non-zeros for LL^T factorization
0 % 1 % 2 % 3 % 5 % 6 % 7 % 8 % 10 % 11 % 12 % 13 % 14 % 15 % 16 % 17 % 18 % 19 % 20 % 23 % 24 % 25 % 26 % 27 % 29 % 30 % 31 % 32 % 35 % 36 % 37 % 39 % 40 % 41 % 42 % 44 % 45 % 46 % 47 % 48 % 50 % 51 % 52 % 53 % 54 % 56 % 58 % 59 % 60 % 61 % 62 % 64 % 65 % 66 % 67 % 68 % 69 % 72 % 74 % 75 % 76 % 77 % 79 % 80 % 81 % 83 % 84 % 85 % 86 % 87 % 88 % 89 % 90 % 91 % 92 % 93 % 95 % 98 % 99 % 100 %
Summary PARDISO: ( factorize to factorize )
Times:
Time A to LU: 0.000000 s
Time numfct : 0.330881 s
Time malloc : 0.000040 s
Time total : 0.330968 s total - sum: 0.000047 s
Statistics:
#equations: 119433
< Factors L and U >
#supernodes: 55725
gflop for the numerical factorization: 5.261862
gflop/s for the numerical factorization: 15.902588
Summary PARDISO: ( solve to solve )
Times:
Time solve : 0.106138 s
Time total : 0.332094 s total - sum: 0.225956 s
Statistics:
#equations: 119433
< Factors L and U >
#supernodes: 55725
Unsymmetric log:
N=119433
================ PARDISO: solving a real nonsymmetric system ================
Times:
Time fulladj: 0.054908 s
Time reorder: 0.915838 s
Time symbfct: 0.106507 s
Time malloc : 0.153521 s
Time total : 1.374198 s total - sum: 0.143423 s
Statistics:
< Parallel Direct Factorization with #processors: > 1
< Numerical Factorization with Level-3 BLAS performance >
#equations: 119433
#non-zeros in A: 1523607
non-zeros in A (%): 0.010681
< Factors L and U >
#columns for each panel: 128
#supernodes: 55613
number of nonzeros in L 15170945
number of nonzeros in U 12859458
number of nonzeros in L+U 28030403
0 % 1 % 2 % 3 % 4 % 5 % 6 % 7 % 8 % 9 % 10 % 11 % 12 % 13 % 14 % 15 % 16 % 17 % 18 % 19 % 20 % 21 % 22 % 23 % 24 % 25 % 26 % 27 % 28 % 29 % 30 % 31 % 32 % 33 % 34 % 35 % 36 % 37 % 38 % 39 % 40 % 41 % 42 % 43 % 44 % 45 % 46 % 47 % 48 % 49 % 50 % 51 % 52 % 53 % 54 % 55 % 56 % 57 % 58 % 59 % 60 % 61 % 62 % 63 % 64 % 65 % 66 % 67 % 68 % 69 % 70 % 71 % 72 % 73 % 74 % 75 % 76 % 77 % 78 % 79 % 80 % 81 % 82 % 83 % 84 % 85 % 86 % 87 % 88 % 89 % 90 % 91 % 92 % 93 % 94 % 95 % 96 % 97 % 98 % 99 % 100 %
Times:
Time numfct : 2.065194 s
Time malloc : 0.000037 s
Time total : 2.065278 s total - sum: 0.000047 s
Statistics:
#equations: 119433
< Factors L and U >
#supernodes: 55613
gflop for the numerical factorization: 9.607209
gflop/s for the numerical factorization: 4.651965
Times:
Time solve : 0.128349 s
Time total : 0.409732 s total - sum: 0.281383 s
Statistics:
#equations: 119433
< Factors L and U >
#supernodes: 55613
Konstantin_A_Intel
It seems you're using rather old MKL version where only symmetrical type of matrices was parallelized for OOC case. In fact, latest 10.2 and 10.3 versions support parallelism for all types.
Which version did you use?
Konstantin
Gennady_F_Intel
more precisely - see the version 10.3 Bug fixes. The problem was market as
DPD200084190PARDISO OOC will now run parallel code for all supported matrix types
Here is the version info:
Major version: 10
Minor version: 2
Update version: 1
Product status: Product
Build: n20090616
Processor optimization: Intel Core 2 Duo Processor
I tested a smaller problem using in-core and I am still using one processor:
calling PARDISO:N=52116
Times:
Time fulladj: 0.014744 s
Time reorder: 0.321509 s
Time symbfct: 0.047079 s
Time malloc : 0.057157 s
Time total : 0.485403 s total - sum: 0.044914 s
Statistics:
#equations: 52116
#non-zeros in A: 525292
non-zeros in A (%): 0.019340
< Factors L and U >
#supernodes: 26576
size of largest supernode: 511
number of nonzeros in L 5768628
number of nonzeros in U 4786806
number of nonzeros in L+U 10555434
0 % 1 % 2 % 3 % 4 % 5 % 6 % 7 % 8 % 9 % 10 % 11 % 12 % 13 % 14 % 15 % 16 % 17 % 18 % 20 % 21 % 22 % 23 % 24 % 25 % 26 % 27 % 28 % 29 % 30 % 31 % 32 % 33 % 34 % 35 % 36 % 37 % 38 % 39 % 40 % 41 % 42 % 43 % 45 % 46 % 47 % 48 % 49 % 50 % 51 % 52 % 53 % 54 % 55 % 56 % 57 % 58 % 59 % 60 % 61 % 62 % 63 % 64 % 65 % 66 % 67 % 68 % 69 % 71 % 72 % 73 % 74 % 75 % 76 % 77 % 78 % 79 % 80 % 81 % 82 % 84 % 85 % 86 % 87 % 88 % 89 % 90 % 91 % 92 % 93 % 94 % 95 % 96 % 97 % 98 % 99 % 100 %
Times:
Time numfct : 0.683435 s
Time malloc : 0.000474 s
Time total : 0.683954 s total - sum: 0.000045 s
Statistics:
#equations: 52116
< Factors L and U >
#supernodes: 26576
gflop for the numerical factorization: 2.780741
gflop/s for the numerical factorization: 4.068774
Times:
Time solve : 0.052398 s
Time total : 0.159472 s total - sum: 0.107074 s
Statistics:
#equations: 52116
< Factors L and U >
#supernodes: 26576
I downloaded 10.3. However, install.sh tells me 10.3 is already installed. I have only 10.2 installed. Why does install.sh tell me 10.3? I assume I need uninstall 10.2 anyway, right?
Initializing, please wait...
The Intel Math Kernel Library 10.3 Update 1 for Linux* is already installed.
If you want to reinstall the Intel Math Kernel Library 10.3 Update 1 for
Linux*
please uninstall current version and run install script again.
Press "Enter" key to quit:
Gennady_F_Intel
Is that commercial/evaluation/noncommercial or whatever version of MKL?
After I update MKL to 10.3, issue resolved. Thanks.
