7260 Discussions
PARDISO works well with IFORT but fails with error -4 in phase 12 when using with IFX
GuoYJ
I am using MKL PARDISO for solving linear equations where the system matrix is real, symmetric, postive definite (with mtype = 2). The codes can be compiled with both IFORT and IFX. However, if IFX (2022, 2023, 2024.0, 2024.2 were all tested) was used, the code always gave me an error code -4 in the phase 12 (actually the phase 11). The fact is that if the code was compiled with IFORT, it worked correctly for the same test cases. Is there any special setting for using PARDISO with IFX? Thanks a lot! Below is my code for calling PARDISO.
BTW, I prefer to use IFX because it seems that the time for preparing the equations (including reading file from the hard disk) is more stable when the code is compiled with IFX. This is important when lots of repeating work is required.
Code for calling PARDISO (on Windows 11):
include 'mkl_pardiso.f90'
subroutine solver_mkl(a,ja,ia,nnz,b,x,n,nrhs)
! Solving linear A*x = B using Intel MKL pardiso direct sparse solver.
! For A, CSR3 format is adopted; Assuming symmetric & positive definite --> upper triangle is used.
use mkl_pardiso
use file_units
implicit none
integer, parameter :: dp = kind(1.D0)
integer, intent(in) :: n ! Number of rows of matrix A = number of equations to solve
integer, intent(in) :: nnz ! Number of non-zero elements in A
integer, intent(in) :: nrhs ! Number of right-hand sides that need to be solved for
real(dp), intent(in) :: a(nnz) ! Values of non-zero elements in A
integer, intent(in) :: ja(nnz) ! Column indices of non-zero elements in A
integer, intent(in) :: ia(n+1) ! Row index, pointing to first column index of each row in ja
real(dp), intent(inout) :: b(n,nrhs)! Single RHS, B
real(dp), intent(out) :: x(n,nrhs) ! Solution of A*x = B
type(MKL_PARDISO_HANDLE) :: pt(64) ! Internal solver memory pointer
integer :: iparm(64) ! PARDISO control parameters
integer :: maxfct, mnum, mtype, phase, msglvl, error1, error2, error3 ! All other variables
integer :: idum(1) ! Dummy variable
real(dp) :: ddum(1) ! Dummy variable
integer :: i ! Loop index
maxfct = 1
mnum = 1
mtype = 2 ! Matrix A: real, symmetric, postive definite -- upper triangle
msglvl = 0 ! Print statistical information
error1 = 0; error2 = 0; error3 = 0 ! Initialize error flag
!! PARDISO control parameters
iparm = 0
iparm(1) = 1 ! No solver default
iparm(2) = 2 ! Fill-in reordering from METIS
iparm(3) = 4 ! Number of threads
iparm(4) = 0 ! No iterative-direct algorithm
iparm(5) = 0 ! No user fill-in reducing permutation
iparm(6) = 0 ! Solution -> x
iparm(8) = 2 ! Numbers of iterative refinement steps
iparm(10) = 13 ! Perturb the pivot elements with 1E-13
iparm(11) = 1 ! Use nonsymmetric permutation and scaling MPS
iparm(13) = 0 ! Maximum weighted matching algorithm is switched-off (default for symmetric). Try iparm(13) = 1 in case of inappropriate accuracy
iparm(14) = 0 ! Output: number of perturbed pivots
iparm(18) = -1 ! Output: number of nonzeros in the factor LU
iparm(19) = -1 ! Output: Mflops for LU factorization
iparm(20) = 0 ! Output: Numbers of CG Iterations
iparm(27) = 0 ! 输入参数检查器开关
do i = 1, 64
pt(i)%DUMMY = 0
end do
phase = 12 ! Reordering, symbolic factorization and numerical factorization
call pardiso(pt, maxfct, mnum, mtype, phase, n, a, ia, ja, &
idum, nrhs, iparm, msglvl, ddum, ddum, error1)
!write(unit_out0,*) 'Space requred 11: ', iparm(17), 'KB'
if(error1 == 0) then
    !write(*,*) 'Number of nonzeros in factors = ', iparm(18)
    !write(*,*) 'Number of factorization MFLOPS = ', iparm(19)
    phase = 33 ! Solving equations
    CALL pardiso(pt, maxfct, mnum, mtype, phase, n, a, ia, ja, &
    idum, nrhs, iparm, msglvl, b, x, error2)
    if(error2 /= 0) then
        write(unit_out0,*) ' ** ERROR was detected in phase 33 of the PARDISO solver: ', error2
        stop 2
    end if
    !write(unit_out0,*) 'Space requred 33: ', iparm(17), 'KB'
else
    write(unit_out0,*) ' ** ERROR was detected in phase 12 of the PARDISO solver: ', error1
    write(unit_out0,*) ' Note: Please check if there are rigid body displacements. Please make sure         there are sufficient &
     &displacement boundary conditions.'
    stop 1
end if
phase = -1 ! Releasing internal memory
call pardiso(pt, maxfct, mnum, mtype, phase, n, ddum, idum, idum, &
idum, nrhs, iparm, msglvl, ddum, ddum, error3)
if(error3 /= 0) then
    write(unit_out0,*) ' ** ERROR was detected in phase -1 of the PARDISO solver: ', error3
    stop 3
end if
end subroutine solver_mkl
Fengrui
It is a duplicate. Discussion happened in this link.
