PSSYGVX - LWORK parameter number 28 had an illegal value
Fábio_A_
Dear Intel Forum,
 I am trying to use PSSYGVX, however if a use a matrix larger than 5000 everytime the function returns:
   PSSYGVX  parameter number   28 had an illegal value
   The info parameter is -28
I tryed to use lwork = -1 (which i believe is the 28 parameter) to ask wich is the optimum value, even with this number a recive the same mensagem. Another values was tested without success. Please, this could be a memory issue ? There any way to debug this ?
 Best regards
Gennady_F_Intel
Fabio, what mkl version do you use and the problem happens when problem size >=5K?
Fábio_A_
Dear Gennady,
 The MKL version is 11.3.3.
Gennady_F_Intel
Fabio, you may try the latest available version of MKL 2018 u1 or please give us the reproducer and we will check the problem on our side.
Fábio_A_
Dear Gennady,
  I just install parallel studio 2018 and the same error occurs.
  Attached the example, the message is:
Best regards.
