Parameter double **mat to cblas_dgemm
Fábio_A_
Dear Intel Forum,
I am developing a molecular dynamic system with a several MKL functions, the atoms position is a  double **mat to the mkl function like cblas_dgemm. However, is necessary to convert the pointer ** to *, like:
void mv(double** m,double* v)
int i = 0, j = 0,z = 0;
   for(i = 0; i < natom;i++)
         for(j = 0; j < natom;j++)
               v = m; z++;
Please, there is a way to use cblas_dgemm without this conversation ?
TimP
No, cblas_dgemm() is simply a wrapper to dgemm() and so the data must be interoperable.
Ying_H_Intel
Hi Fabio,
is the pointer of double **mat  point to a continuous memory?   If yes, then you don't need to change,  just feed the cblas_dgemm with
cblas_dgemm(&m[0][0],  ...)
it should be ok
Best  Regards,
Ying
Here is one sample:
    A = (double *)mkl_malloc( m*k*sizeof( double ), 64 );
    B = (double *)mkl_malloc( k*n*sizeof( double ), 64 );
    C = (double *)mkl_malloc( m*n*sizeof( double ), 64 );
    if (A == NULL || B == NULL || C == NULL) {
      printf( "\n ERROR: Can't allocate memory for matrices. Aborting... \n\n");
      mkl_free(A);
      mkl_free(B);
      mkl_free(C);
      return 1;
    printf (" Intializing matrix data \n\n");
    for (i = 0; i < (m*k); i++) {
        A = (double)(i+1);
    for (i = 0; i < (k*n); i++) {
        B = (double)(-i-1);
    for (i = 0; i < (m*n); i++) {
        C = 0.0;
    printf (" Computing matrix product using Intel® MKL dgemm function via CBLAS interface \n\n");
    cblas_dgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans,
                m, n, k, alpha, A, k, B, n, beta, C, n);
Fábio_A_
Thank you for the reply.
Is point to a continuous memory, i tried this solution, but the solution in different when i use this solution, even with Row ou Col major...
