Parameters of the objective function for the nonlinear fitting routine
Cheng_C_
I want to conduct a nonlinear least square fitting using MKL. However, I don't know how I can introduce some additional parameters for the objective function. Does anybody have some ideas?
This is the introduction of the routine: https://software.intel.com/en-us/node/471086
This is one example code for the routine: https://software.intel.com/en-us/node/471540
How can I past some parameters for the objective function (the f(x) function in the introduction or the extendet_powell() function in the example code)? Thanks very much.
mecej4
One way is to add an array containing the parameters to the argument list of the vector function that is being optimized. You declare and initialize the array in the caller of the optimizer routine, and take care to modify the DJACOBI routine if you are using numerical evaluation of the Jacobian.
Alternatively, in Fortran, put your parameters declarations and initializations into a module, and USE that module in the callback subroutine. For example:
MODULE PARAMETERS
   IMPLICIT NONE
   DOUBLE PRECISION :: P(5) = [ 10.D0, 2.2360679774998D0, -2.D0, &
                                3.1622776601684D0, -1D0 ]
END MODULE PARAMETERS
SUBROUTINE EXTENDED_POWELL (M, N, X, F)
  USE PARAMETERS
  IMPLICIT NONE
  INTEGER M, N
  DOUBLE PRECISION X (*), F (*)
  INTEGER I
  DO I = 1, N/4
      F (4*I-3) = X(4*I - 3) + P(1) * X(4*I - 2)
      F (4*I-2) = P(2)*(X(4*I-1) - X(4*I))
      F (4*I-1) = (X(4*I-2) + P(3)*X(4*I-1))**2
      F (4*I)   = P(4)*(X(4*I-3) +P(5)* X(4*I))**2
  ENDDO
END SUBROUTINE EXTENDED_POWELL
Similarly, in C, you can use global variables to contain the parameter values.
Cheng_C_
Thank you for the suggestions! I'd like to try both ways.
MODULE PARAMETERS
   IMPLICIT NONE
  USE PARAMETERS
  IMPLICIT NONE
  INTEGER M, N
  INTEGER I
  DO I = 1, N/4
  ENDDO
