7302 Discussions
Pardiso format Vector Manipulation Library in MKL
Ngu_Soon_Hui
I just wonder whether there is any vector/matrix manipulation library in MKL if my data is stored in pardiso format? The library shall include, but not limited to factorization, linear system solver, matrix vector product.
This is because for band matrix, lapack has readily available matrix/vector manipulation library (see for example, sgbtrf and sgbmv), which comes in handy when one needs to do ARPACK eigen solvers ( see an example here). However, a lot of times we don't use band matrix storage format and instead, we opt for pardiso format ( is it CSR or CSC or a variant of any of the two? I'm not very sure).
A similar library for Pardiso would be great aid for everyone.
ArturGuzik
Valued Contributor I
I'm not entirely sure what you have in mind, however, you may take a look at the Sparse BLAS level 2 and 3 routines (in MKL), which provide (most probably) what you want, including all sort of multiplications, conversions etc.
A.
ArturGuzik
A.
Gennady_F_Intel
Quoting Ngu Soon Hui
one more comment on this - Pardiso supports only one CSR format ( 1-based indexes).
--Gennady
