7299 Discussions
Pardiso matrix size change over the simulation
Tabrizian__Amin
Dear all,
I have just started learning PARDISO and I face a question:
How can we use PARDISO when our coefficient matrix size changes over the simulation?
I know that we can simply solve this issue by reinitializing PARDISO but maybe a special order of steps needs to be followed to avoid this inefficient using of PARDISO.
Kirill_V_Intel
Hi Amin,
You need to formulate on the level of mathematics how you would like to re-use the matrices. PARDISO is a way to factor the matrix and then solve the system. For example you can use one of the matrices as a preconditioner. Or you can use the Schur complement technique.
Best,
Kirill
Kirill_V_Intel
Hi!
First of all, please clarify what do you mean by changing the coefficient matrix size? And how do you want to re-use the original matrix on the high-level? For example do you have an extended system where the original matrix is a sub-block (maybe with slightly changed matrix values but with the same pattern)? Or do you have a completely different new larger matrix (for example when you change the discretization step when solving numerically some PDEs)?
Best,
Kirill
Tabrizian__Amin
Hi Kirill,
Thank you for  your reply. I mean how we can use PARDISO when size of our system of equations changes over the simulation? And about re-using the original matrix,  our original matrix may change by adding some rows(columns) or omitting some.
Amin
Kirill_V_Intel
Hi Amin,
Best,
Kirill
