7303 Discussions
Pardiso : memory release problem (MKL 10.1.1.019)
minos67paran_com
Hi, I am trying to use the Pardiso solver for the nonstationary Navier-Stokes equations.
The only problem is that the system memory is increasing constantly.
I tried MKL_FreeBuffers(), but it was not working.
I am curious to know if the problem could be fixed.
Is anyone who use Pardiso solver to the dynamic PDE problems?
Any comment would be appreciated.
euan
hi,
i think you're doing the "return 0" at the end of your program before freeing your memory. I would have thought the compiler would have warned you of this, but then again I'm used to C# which tends to be more friendly
Yes, I did.
The following is a part of code calling pardiso.
I modified pardiso example code in MKL.
(I found that the c-code example usefortran array convention(starts index 1 for *ia, *ja).)
If there are somthings missing, please make some comment.
Sparse : custom structure for a sparse matrix
SparseToPardisoRowNum( mat, ia ); SparseToPardisoMat( mat, ja, a ); : custom function which I believe there
is no problem...
int PARDISO_SOLVER_ICC(int nn, Sparse *mat, double *bb, double *xx )
/* Matrix data. */
MKL_INT n = ((MKL_INT) nn);
MKL_INT i, MKL_temp;
MKL_INT *ia, *ja;
double *a;
ia = (MKL_INT *)malloc( (n+1)*sizeof(MKL_INT) );
MKL_temp = SparseToPardisoRowNum( mat, ia );
// printf("check point -5. %dn", MKL_temp);
ja = (MKL_INT *)malloc( ia*sizeof(MKL_INT) );
a = (double *)malloc( ia*sizeof(double) );
MKL_temp = SparseToPardisoMat( mat, ja, a );
printf("Non-zeros of Pardiso mat = %dn", MKL_temp );
// printf("Non-zeros of Pardiso mat = %dn", SparseToPardisoMat( mat, ja, a ) );
// printf ("n");
// for (i = 0; i < n+1; i++) printf("ia[%d] = %dn", i, ia );
// printf ("n");
// for (i = 0; i < ia; i++) printf("ja[%d] = %dn", i, ja );
// printf ("n");
// for (i = 0; i < ia; i++) printf("a[%d] = %fn", i, a );
MKL_INT nnz = ia;
MKL_INT mtype = 11; /* Real unsymmetric matrix */
/* RHS and solution vectors. */
double *b, *x;
MKL_INT nrhs = 1; /* Number of right hand sides. */
b = (double *)malloc( n*sizeof(double) );
x = (double *)malloc( n*sizeof(double) );
/* Internal solver memory pointer pt, */
/* 32-bit: int pt[64]; 64-bit: long int pt[64] */
/* or void *pt[64] should be OK on both architectures */
// void *pt[64];
int pt[64];
/* Pardiso control parameters. */
MKL_INT iparm[64];
MKL_INT maxfct, mnum, phase, error, msglvl;
/* Auxiliary variables. */
double ddum; /* Double dummy */
MKL_INT idum; /* Integer dummy. */
/* .. Setup Pardiso control parameters. */
for (i = 0; i < 64; i++) {
iparm = 0;
iparm[0] = 1; /* No solver default */
iparm[1] = 2; /* Fill-in reordering from METIS */
/* Numbers of processors, value of OMP_NUM_THREADS */
iparm[2] = 1;
iparm[3] = 0; /* No iterative-direct algorithm */
iparm[4] = 0; /* No user fill-in reducing permutation */
iparm[5] = 0; /* Write solution into x */
iparm[6] = 0; /* Not in use */
iparm[7] = 2; /* Max numbers of iterative refinement steps */
iparm[8] = 0; /* Not in use */
iparm[9] = 13; /* Perturb the pivot elements with 1E-13 */
iparm[10] = 1; /* Use nonsymmetric permutation and scaling MPS */
iparm[11] = 0; /* Not in use */
iparm[12] = 1; /* Maximum weighted matching algorithm is switched-on (default for non-symmetric) */
iparm[13] = 0; /* Output: Number of perturbed pivots */
iparm[14] = 0; /* Not in use */
iparm[15] = 0; /* Not in use */
iparm[16] = 0; /* Not in use */
iparm[17] = -1; /* Output: Number of nonzeros in the factor LU */
iparm[18] = -1; /* Output: Mflops for LU factorization */
iparm[19] = 0; /* Output: Numbers of CG Iterations */
maxfct = 1; /* Maximum number of numerical factorizations. */
mnum = 1; /* Which factorization to use. */
msglvl = 1; /* Print statistical information in file */
error = 0; /* Initialize error flag */
/* .. Initialize the internal solver memory pointer. This is only */
/* necessary for the FIRST call of the PARDISO solver. */
pt = 0;
/* .. Reordering and Symbolic Factorization. This step also allocates */
/* all memory that is necessary for the factorization. */
phase = 11;
PARDISO (pt, &maxfct, &mnum, &mtype, &phase,
&n, a, ia, ja, &idum, &nrhs,
iparm, &msglvl, &ddum, &ddum, &error);
if (error != 0) {
printf("nERROR during symbolic factorization: %d", error);
exit(1);
printf("nReordering completed ... ");
printf("nNumber of nonzeros in factors = %d", iparm[17]);
printf("nNumber of factorization MFLOPS = %d", iparm[18]);
printf("check point 2. n" );
/* .. Numerical factorization. */
phase = 22;
if (error != 0) {
printf("nERROR during numerical factorization: %d", error);
exit(2);
printf("nFactorization completed ...n ");
/* .. Back substitution and iterative refinement. */
phase = 33;
// iparm[7] = 1; /* Max numbers of iterative refinement steps. */
iparm[7] = 2; /* Max numbers of iterative refinement steps. */
/* Set right hand side. */
for (i = 0; i < n; i++) {
b = bb;
iparm, &msglvl, b, x, &error);
if (error != 0) {
printf("nERROR during solution: %d", error);
exit(3);
printf("nSolve completed ... ");
printf("nThe solution of the system is: ");
xx = x;
// printf("n x [%d] = %24.16e", i, x );
printf ("n");
/* .. Termination and release of memory. */
phase = -1; /* Release internal memory. */
&n, &ddum, ia, ja, &idum, &nrhs,
return 0;
printf("n PARDISO_SOLVER done !");
MKL_FreeBuffers();
free(ia);
free(ja);
free(a);
free(b);
free(x);
euan
Have you called it with the phase parameter set to -1? Think you need to do that to free the memory
minos67paran_com
Yes, I did.
is no problem...
/* Matrix data. */
MKL_INT *ia, *ja;
double *a;
// printf ("n");
// printf ("n");
// printf ("n");
MKL_INT nnz = ia;
double *b, *x;
// void *pt[64];
int pt[64];
MKL_INT iparm[64];
iparm = 0;
iparm[2] = 1;
pt = 0;
phase = 11;
if (error != 0) {
exit(1);
phase = 22;
if (error != 0) {
exit(2);
phase = 33;
b = bb;
if (error != 0) {
exit(3);
xx = x;
printf ("n");
return 0;
MKL_FreeBuffers();
free(ia);
free(ja);
free(a);
free(b);
free(x);
euan
hi,
Yes, I did.
is no problem...
/* Matrix data. */
MKL_INT *ia, *ja;
double *a;
// printf ("n");
// printf ("n");
// printf ("n");
MKL_INT nnz = ia;
double *b, *x;
// void *pt[64];
int pt[64];
MKL_INT iparm[64];
iparm = 0;
iparm[2] = 1;
pt = 0;
phase = 11;
if (error != 0) {
exit(1);
phase = 22;
if (error != 0) {
exit(2);
phase = 33;
b = bb;
if (error != 0) {
exit(3);
xx = x;
printf ("n");
return 0;
MKL_FreeBuffers();
free(ia);
free(ja);
free(a);
free(b);
free(x);
minos67paran_com
Thank you euanw!
After changing the function from int type to void type, the trouble is resolved.
